Picture message on CM10
kingjay2012
OK my girlfriend sent me a picture today and it came through in notification and when I opened it up nothing was shown as far as the pictures as if I never received it, why is it doing that?
An MMS message?
Sent from my Nexus 4 using Tapatalk 2
Yes, nothing is showing up when I click on the notification in my notification screen.
There even isn't a option to downlad the picture message.
Not sure if CM ever really worked with MMS, I don't recall it doing.
We share photos over Picasa or just email.
I have my msl number, but I don't know how to access data or what the ##3828# is I dialed that in the phone and got nothing, what do I do?
OK I downloaded both the boostfixmms.zip and the cm9fixmms.zip which 1 do I flash and do I have to clear anything in cwm afterwards?
Ok I did and had her send me another picture and it still came through as a blank message smh... the notification is there but nothing shows up when I press the message notification as it goes into messaging.
Did I have to flash it in a certain order or something because its done a lot of foreclosing in my text messaging, picture messaging, and gallery. Also it forecloses alot when I press the menu button in certain apps as well....
That sounds like you have other issues going on. what ROM did you install? did you do any wipes as required by the install instructions for that rom? I am using a TW JB ROM myself so I had only a couple MMSC changes to manually set.
Yeah I did factory, cache, and dalvik cache then installed the rom and gapps. But it say currently can not send your message. Your message will be sent when the network becomes available, what did I dowrong
Lol hold up y'all. This is a simple fix..!!!!
Codegerm its the same fix you gave me months ago just without being able to use the hidden menu..
Hold tight let me grab 1 link and take screenshots to show you what to do!!! BRB
This will take you about 2 mins without even rebooting or going into recovery
1st thing go download this from the market
https://play.google.com/store/apps/details?id=com.google.android.apps.gesturesearch
2nd. Open app let it set itself up. Draw APN
Click on the apns setting
Now click the 3rd one that has internet at the end..
Now scroll down and change your mmsc URL and MMS proxy to match mine.. Yours will say sprintpcs.com instead of myboostmobile.com
And your Proxy will end with 7 instead of 1.
After changing those 2 things hit menu then save apns..
Now your MMS will work!!!!
This method will work on all sprint aosp roms
Nice fix. Nothing is more aggravating when the hoe in town says I finally got my boobs done check thesse out nd no pic comes through. 2 thumbs up dude.
