So Panasonic Plasma it is unless I can find one of those fabled Pioneer Kuros ... and don't get the G1 series.
Does this about sum it up?
Plasma: "Old technology," that's the biggest reason it's so cheap. That said, a good plasma puts out one of the best pictures you can get. Phenominal color contrast, very dark blacks, and, as you noticed, it's cheap. Static images used to cause a "burn-in" effect that would leave a ghost image on your screen permanently, but that's all but completely gone.
The downside is that it's heavy, about 2x the weight of a similar size LCD, probably 4x the weight of an LED. Also, over time the colors will start to fade, but it'll still look great with 45,000+ hours on it.
LCD: To me, this is the sweet spot. LCD is also "old" technology but it's really in it's prime right now. A few years ago you'd be paying out the nose for an LCD larger than 47", now they're available all over the place. The contrast ratio has gotten MUCH better on these the past few years (Dynamic contrast on my May '07 LCD is 3,000:1, now most are 100,000:1 or better).
Downsides are few. The picture isn't going to be quite as "pop off the screen" as a really good Plasma or LED, but it'll still look fantastic. No worry at all with burn in or screen fade, although eventually pixels may die. It costs a bit more than Plasma (usually) but nowhere near as much as LED.
LED: This TV uses an LED backlight instead of an LCD backlight. That means you're getting deeper blacks and a much thinner panel, but that's about where the edge over the competition ends. While it's great to have a panel that's 2" thick, in my opinion it's not worth the premium over LCD.
Downsides are obvious: It costs alot. That's the same with any new "cutting edge" technology.
Personally, I'd go Plasma or LCD, LED just isn't worth the cost.
If there's one bit of advice I wish I'd have before buying, it's to spend the extra money on a higher end model of the same size, even if the tech specs appear to be the same. I got a lower end one that just had a less effective anti-glare but was otherwise identical thinking that since I watch mostly at night that it wouldn't matter. I now wish I'd spent the extra couple of hundred on the one with the better anti-glare for those times I do watch TV while the sun's out...
No such thing as an "LCD backlight" LCD is the display panel. It's either LED or CFL.
I'll do one better. Get the biggest screen you can comfortably handle (and that won't overcrowd the room) because inevitably you WILL wish you had a bigger TV. I was sure 42" would be perfect forever...about 6 months later my buddy got a 52" and I coveted it greatly. I wish I had at LEAST a 50" now (which sucks because you can get a heck of a 50" TV for what I paid for my 42" back in '07), if not a 55"+.
I was going to settle for the 42".. you guys really don't think it's not big enough? I mean I could upgrade to the 46" but that one is $243 more (amazon vs amazon)![]()
42" is more than big enough for a bedroom. If I was going to go the route of buying a new TV though, I would go 50"+ for the living room.
ehh. If I was putting it up on the wall and sitting 11+ feet away I'd care. I think I'll be fine with the 42.. I'd like to put that $243 to something else right now.
New pr0n collection? lololol.![]()
If you have extra money to spend, use it on getting a higher end model, not a bigger version of a low to middle end model.
Thats decent price for sure for that model. IMO 1080P plasma is still the top dog although the led ones are nice too.I was looking at this model
Samsung 50" 1080p 600Hz Plasma HDTV PN50C6500
I hear that Samsung copied the same technology as the Panasonic Viera series.
Is the pricing reasonable?
