mrpnut
THE WORLD IS YOURS
hey chicano...i downloaded it... ok now whats next?![]()
K if your talking about ROM manager your going to open it and click on flash clockworkmod recovery and choose your device which is under lge esteem
^ what he said
(To be honest? I cant even tell you the last time I made a back up.)
I literally have anywhere between 40-50 backups. And these are current backups for ZVD since I re upgraded 2 or 3 months ago.
I have a 1TB external on my PC and that's where all my ANDROID stuff goes so I figured, meh, why not.
I also save every version of every ROM I can. Themes not so much unless they are themes Im using.
Im a hoarder. lol I have about 4-5 sets of drivers, guides, tools, 4-5 different apk tools, yada yada yada.
Plus, why you gonna put that in her(his) head? lol.
lol same here bro
As long as you have an external sd card youre golden![]()
Plus Im OCD a bit so if I get to the point I have to restore I just reflash clean![]()
This is true. But myself also being OCD the thought of NOT having at least one backup on my SD makes me shake, cold sweats, vomiting with periods of passing out. haha
Freezing doesn't cure my ocdSo what's the status? Did you get a backup made?
One you do that you can use titanium to uninstall the apps of your choice.
Once you get your phone setup how you want with your rom, theme, apps etc....... Go and make a backup of your phone setup to your liking. That way if you have to use a backup you can go back to how your phone was and not have to start all over again installing stuff, apps roms themes etc....
Also don't uninstall an app your not sure about. Just ask before you uninstall. And remember you can always freeze an app.![]()
it may not work, but it's still there, and that bugs me for unknown reasons.
also that folder that is named CLOCWORKMOD ON YOUR SD CARD IN THE EXTERNAL SD BE SURE TO MAKE A COPY ON YOUR PC OR LAP TOP . THIS IS SO IF YOU EVER MAKE A MISTAKE AND WIPE SD CARD U ALWAYS HAVE THIS BACK UP TO PUT BACK ON YOUR SD CARD AND flash back into business . AND THIS WILL ALSO KEEP U IN THE GOOD AND GREEN LIGHT IF YOU HAVE TO RETURN THE PHONE CAUSE U HAVE THE BACK UP OF THE ROM U USING .Welcome to AF chat2jessica yes I recommended updating your phone to zvd make sure iu have it on internet connection once your done, you can use the same method you use to root your phone, after all the good stuff download rom manager once that's downloaded open it up and choose flash cwm recovery choose your device which will be lgeesteem after you do that scroll down till you see back up current rom click on it and rename what you want then press OK after it should boot in to recovery and thata gonna back up your current rom ,Good luckanything happens let us know we have a bunch of good people that could help you out
Oh wow thanks..I'm gonna try that...but how can I change fonts and themes and sounds and icons? You guys are so cool...lol....I'm learning![]()
Oh hey BTW I just uploaded a profile pic...can anyone see it on this thread cuz I cant..is that normal?
