mostly from the play store. what were you looking for?ive successfully rooted , but.
Where do i get rooted apps?
rooting doesn't mean only special apps.i got it... and could you help me with putting koumakernel 2.5 on it? everytime i try , the phone bricks and i have to reset and re-root it..
i used CTmod . but i dont like the look of it.. and the keyboard.. and that you cant use live wallpapers.. i just tried to get it from koumajitsu's post.
I dont know why. I just like gingerbread better
if i installed kk 2.5 with clockwork , would that work?
wow!!!! just look?Where would i find this "half ass" rom at?
like he said you can add remove and adjust to whatever you wantJust add live wallpapers with the removed apps zip, also add the CTkeyboard from the same list, I hate the ics keyboard too
it's all ver adjustable!!!
copy to sd card and then flask in cwm, open it first and dump all that don't want or install all then use a file explorer to get rid of all that don't want.this is going to sound REALLY stupid but this line
--> Boot into CWM and flash it
what does he mean by flash it?
sorry about that one post, didn't mean to sound mean it's just that what you asked about was right there in front of youthis is going to sound REALLY stupid but this line
. but still here to help.this is going to sound REALLY stupid but this line
Use half ass rom. It is stock modified to work with kk2.5
Also this sounds like the cheesy sales pitch after my thread today (I'm not trying to do that) But you are the perfect canidate for this problem..
So, please, please, please tell me you have made some sort of backup already? It saves from having to use ODIN 3-4 times a day lol.
