Root PORT : Saber Pac Rom 4.4.4 LG L90
Got g2 mini full stock ported. Everything tested so far is data...working in 3G mode only atm. Need to test calling. Not sure its even worth posting. Can if people want it just to try it out.
Updated rom and added an alternate rom for those who want an alternative music system and keyboard. Along With Fixes..
Downloads in main OP.
- Both Roms Contain Fixes For -
Touch Buttons Lag In Dialer During Calls
Touch Button Lag Waking Device
Removed Unsupported Touch Init.d Scripting And It's Settings In Init.d Options
Removed Outdated Yahoo Weather And It's Settings In Notification Drawer Options
- Pac Rom Alternate -
Alternate Music System - Walkman Music With Equalizer
Alternate Keyboard - Xperia Z2
I love this ROM but for one annoying thing. See pic attached. I want to get rid of this cloud thing at top of pull down screen all I need is pure black. Am I overlooking some setting in PAC settings? I'm still using the ROM from few weeks ago not the newest one uploaded by Curtis few days ago.
As far as my testing went,weather in notification panel did not work. Removed it in new rom. Not sure how you got it going unless it was through gps location because the enter custom location definitely did not.
Can not get xposed to work and in one of the many threads I remember some body had a fixed version. I get the incompatible with sdk 19 error
MANUAL CHANGE:
1. GO TO /SYSTEM/ETC AND LOCATION MIXER_PATHS.XML
2. OPEN FILE USING A TEXT EDITOR OR DOWNLOAD AN XML EDITOR FROM THE PLAY STORE.
3. SCROLL DOWN CLOSE TO THE BOTTOM AND LOOK FOR <PATH NAME="SPEAKER">
4. BELOW IT YOU WILL SEE THIS LINE:
<ctl name="RX3 Digital Volume" value="84" />
5. CHANGE VALUE FROM "84" TO WHATEVER YOU WANT, I RECOMMEND 90 - 95.
6. SCROLL TO THE VERY TOP OF THE SCRIPT AND FIND:
<ctl name="RX1 Digital Volume" value="84" />
<ctl name="RX2 Digital Volume" value="84" />
<ctl name="RX4 Digital Volume" value="84" />
7. CHANGE ALL OF THESE VALUES TO THE SAME VALUE YOU SET AT BELOW.
8. SAVE CHANGES AND REBOOT.
9. ENJOY!
Virgin mobile.
Sometimes, usually after disabling airplane mode, my data connection goes away and doesn't come back until I do a reboot. Does anyone have the same problem and\or a fix? Thx in advance!
Virgin mobile.
I get this only after virgin mobile has started throttling of data. Never before. Its virgin mobile that is the cause.
