Root Portal Boot Animations *UPDATED*
cr5315
Aperture Science is pleased to announce a new line of Ally Boot Animations!
The installation is easy:
1) Download the animation of your choice
2) Move your animation to your sdcard
3) Boot to recovery
4) Flash your animation
5) Reboot for cake
NEW
The Aperture Science and Aperture Science Innovators animations, splashes, and sounds are now available in the Velocity Script v38 Just use the Velocity Toolkit and the Terminal Emulator to install!
Animations
Aperture Laboratories:
Animation:
Splash Image:
Boot Sound:
Preview
Download:
Download Aperture Science V1.2
Aperture Science Innovators:
Animation:
Splash Image:
Boot Sound:
Preview
Download:
Download Aperture Science Innovators V1.1
Wheatley Laboratories:
Animation:
Splash Image:
Boot Sound:
Preview Boot Sound
Download:
Coming soon!
POTaTOS
Coming soon!
Animations tested on Velocity 1.1
To enable boot sounds, open the Velocity Toolkit app. Select the System Settings button and check Boot Sounds.
Thanks to j2cool2012 for helping me!​
Can't wait to try it! :D
Thanks.
EDIT: I did a nandroid backup, and flashed the zip. The splash image worked, but then shows this after about 2-3 seconds:
V E
L O
C I
T Y
and then the normal velocity boot animation that looks like the ANDROID animation.
I will try and flash again and see if that works.
EDIT 2: Flashed again and I have the same results. :(
Thanks for the feedback. I'll look into that and hopefully I'll have a newer version later tonight.
EDIT: I updated the animation files. Download this new one and see if it works.
Thanks.
V E
L O
C I
T Y
Its little thinks like this that make me giggle every time I pick up my phone. My wife thinks I'm crazy or its loaded with porn. No matter. Thanks for the time for this.
The animation part seems to be fixed, the Apeture Lab fading in and out cycles until the phone is ready to use. Good stuff.
The initial logo though, I'm experiencing the same. A couple seconds of the Apeture logo, then the stacked Velocity until the bootanimation. Not that I don't love what Team Velocity has done, but the Apeture Logo is much cooler.
Thanks again CR
Thanks again CR
The stacked Velocity is not a part of the splash screen. That will always be there, but you can change it from the scripts, methinks. Unless there is a way to change that along with the others, the Velocity stays.
The
VE
LO
CI
TY
Screen has to be in the boot.img, because I've flashed different recoveries with V1.1 and it didn't change. So the only way I can think to change/remove that screen is to decompile the boot.img and modify it from there..I would think by pulling apart a nandroid then restoring after the modification.
d0nd0n and skora:
I updated the files and now the boot animations should work for you. Thanks for downloading my animations!
I Love Velocity... but I'd really love it if that stacked logo would get replaced, possibly with the one in Version 1.0.
Gee... remember when there were REAL issues to gripe about?
Agreed, it's not my all time favorite boot screen but it's definitely cool. Plus I mean it's on there for like what 5 seconds? Flip your phone over, blink, look away or stare at it really closely until you can see the little Android devil logo pop out like those old 3D pictures
non of them working on RCMix Runny 1.3 for desire hd :( i could install only the animation manually in /data/local
i also have a nice idea for boot sound, when Glados says: 'It's been a long time! How have you been?'
oh and the link for the top one is broken.
