xliderider
Android Expert
I believe there is a bug in the signal strength indication on the Fascinate, the one that shows the signal strength in -dBm.
You can see the signal strength of the cell signal on the Menu, Settings, About, Status screen. Or you can place a widget on your Home screen. There are several widgets available, I'm using Mobile Signal Widget.
I have a network extender, which basically creates a cell tower right in your home. With my Motorola Droid, I used to get signal strengths down to about -50 something and 60's in indicated signal strength. I can hold both of our Fascinates right next to the network extender's antenna and they will read no better than -86 dBm. So far I've seen signal strengths from -86 dBm to -106 dBm (terrible).
I believe there is a bug in the software (Baseband) on the Fascinate. Previously, I thought the hardware (antenna/radio) wasn't very good, but now it may be software related.
Has anyone seen a signal strength stronger than -86 dBm on the Fascinate?
