i may be overlooking something easy here, but how do you put a picture on your desktop? not a wallpaper, but it looks like some of you have a picture "widget" almost.
anyone?
anyone?
Wow, where did u find that 4th of july theme?
That 4th of July theme was custom made for a contest on Droidforums.net
I think you are referring to the "Picture Frame" widget. It's a stock widget on android as far as I know. When you select it, it will have you go to your gallery to select a picture. You will then be able to crop it and add it to whatever home screen you like.
If that's not the answer you're looking for, give a specific example of what you are looking at from another persons screen.
Hope this helps.
Thank you very much
with the latest LP update, i went to 1 screen. changed it to 5 rows, and here you are, everything i need on one screen. all icons are on the dock.
