Post Your LG Volt Screenshot...
Stock launcher & fonts, anybody know how launchers compare in memory usage, just curious as I notice all the different ones being used
Here is mine. Running a ported LG g3 home and keyboard. Zooper widget for the LG g3 clock. And stock LG g3 wallpaper.
Mine is pretty basic and I just got it so haven't done much to it at the moment.
I don't use the lock screen because of the virgin mobile text that was on there.
my screen when not in use, dash clock widget (kk one), flower closed.
flower open
you can double tap a bubble for a widget or secondary action. In this case the music bubble opens up the GPM widget. I have the all access subscription.
swiping from the left to the right opens up the app drawer.
lock screen has no brackets
I tried going for a cleaner look, so far I think it's cleaner and cooler. It also uses a lot less ram and androids run a LOT smoother.
That's smart launcher right?
Yes, lightweight, beautiful and innovative. It's just different and awesome. I bought it a long time ago and don't know why I didn't always use it. I always liked the idea of a vanilla android but I've realized that as much as Google tries to cut ram usage in their os, they really don't put any effort into cutting ram usage in their apps. There's much better alternatives out there as far as apps go. I just hate that not everything is as well consolidated as Google products are where it's an "all in one" type thing.
Yeah, I tried out smart launcher... Didn't like the limit on widget placement though. Doing well with Holo Launcher HD. :)
I try to stay away from widgets because they use so much ram, one thing I did like about smart launcher is that you can double tap a bubble and it'll bring up a widget, but when you're done with it it'll clear up the ram, ask I'm saving a lot on ram usage with it. The only widget I use is dashclock which is where my clock is.
I get what you're saying, but I've got Chronus w/dashlight extension, Kobo widget, and WiFi Tether widget and still have 305MB free, do the widgets are only using 45MB.
