Root Power Off 2.3.4
Fuzzy13
Extreme Android User
What the heck is it and what does it do? I always uninstall it because I've never seen any ill side effects but what does it do? Just curious ;)
And DunServer 2.3.4. Wtf is that as well. I delete that too.
I've never seen this until the Esteem though. O.o
V SuperUser V said:
After deleting The power off.apk have you try powering off the phone through the power menu?
Yeah i do it all the time. That's how i reboot/recovery if i'm not in commander which then I'll just do it in there.
ManlyParasite said:
Dun I believe is the dial up server, something to do with Bluetooth, might been used for tethering
Could be the case. I delete all the bluetooth stuff anyways.
be careful deleting apk's that you are un sure of. ;)
Usually I am, I try to google anything before uninstalling it. But you can usually tell if it might be something you SHOULDN'T uninstall. I figured power off wouldn't affect anything directly.
But I was more wandering about what it does. I've been uninstalling that apk since I got the phone and I've never noticed what it does. Curiosity always gets the better of me ;)
hu huh, plus i hate the metro pcs power off image, but there is some that can be put in it's place.
