Help Problem pushing apps on Nook Color
nedroid
I rooted my NC and can use the market to install apps but can't install the Gingerbread KB.
If I use adb push I get a warning "Read Only File System". I've tried chmod 777 chmod -R 777, etc and get permission denied errors. I've tried su but don't have a password.
Tried using File Manager app, terminal emulator and got same errors.
I used auto nooter 2.12.25 on a 1.01 system.
I'm doing this on a Mac using iTerm. I seriously doubt that using Terminal would make any difference, as I manage several Linux servers from iTerm.
Would really appreciate some help or suggestions. :D
Are you saying there is no way to do this without purchasing this app?
You can use adb to set the system partition for read/write access. This is the code you need.
Code:
adb shell
#mount -o remount,rw /dev/block/mmcblk0p5 /system
#exit
Source for this was found at XDA
Code:
adb shell
#exit
Thanks!
Worked beautifully.
I had searched the XDA site but not their forums. I have now enrolled there.
I am wary of using graphical file managers with nix boxes. Had one really horrible experience a few years back. More comfortable with the CLI.
Thanks again for the help! :D
