Root Q & A for all things DL30 leaked
neotrixy
Got some questions for anyone that has the answers. I'm referring to Adrynalyne's DL30 Super Clean 05, in specific.
#1: Is this a completely working version of 2.2? Is there anything that doesn't work?
#2: When I flash this, with it having a new kernal and all, will all my contacts and txt messages and apps and everything else still be there or are those going to get wiped in the data wipe that I have to do while installing?
#3 Can anyone confirm that Flash is working? This is really the only reason why I am making the switch
#4: And does the wifi tether app still work for rooted phones? that's key for me!
Thanks for everyone with answers and for all the coders that worked on these releases and the man who had the grapes to leak this!
A. its as functional as anything else...you ll get fc's in the dialer with voicemail button though...and battery life aint great until we get a radio leak
your contacts *should* be backed up if theyre google contacts...if you make them phone contacts you can back them up to your sdcard under import/export...you will loose ur texts
in a word: yes
it should work...theres some conflicting thoughts on wether or not tethering can be monitored though...i think its ok...but idk :o
I think Nits answered everything as good as it can get.
Battery life doesn't seem horrible right now considering imo. The Wifi Tether is something I'm going to stay away from until we know for sure. I don't use it a lot but I like having the option to use it when I need it.
Flash works 100%.
Chrome to Phone works as well.
The only issue I'm having currently is the e-mail not wanting to work and when it does it says "Message too long to be displayed".
Hmm I tried flash and it seems to not work, for example if I go to site like hbo.com
or like tvguide.com
What sites have you tested flash at?
Hey guys, first post here. I have been lurking for forums for quite some time. I got my fascinate in December. I am rooted and was running DJ05 with an UV kernel til now. I just flashed the FROYO update and all is running well......except, my computer will no longer recognize the phone when i plug it in. I am using the same usb cable that came with the phone and everything. Can anyone else confirm? I am thinking that maybe the usb drivers need to be updated again.
*edit*
Figured it out. I switched my setting from mass storage to *ask upon connection* I also turned on USB debugging and was able to get my phone to be recognized.
yep i delete, reinstalled and rebooted phone and when i go to hbo.com it tells me my device does not support flash
Any other idea?
also tried this site no good
Flash Games - Play free games
hmm and tried this site
www.whatismyflash.com
and tells me i have no flash player installed
some sites dont accept mobile devices regardless of their flash compatibility..ie hulu...i dont know if thats the case in your situation though
ok finally got it to work, have to go into the browser and go to settings, and go to enable plugins, and choose always on.
Had no idea that option was there.
Also does your web browser now always stay in wide screen mode no matter which way you turn your phone? Even though I have it checked to Auto Rotate screen
edit: nm it liked all my settings got messed up in browser even though i wiped it clean, there is an option in browser to have it always go landscape
Looks like I'm late to this party. Just a couple more questions -
I want to try the super clean version, does voodoo need to be disabled and do I need the new CWR? I understand I need that for the bloated version, but unsure if needed for super clean.
Which kernels can I use with the super clean version? I'm currently using a voodoo imunut kernel.
Thanks repeatedly for all of your help. I'll be sad to leave 2.1 because I won't have the lovely purple theme.....
voodoo is not compatible with dl30 kernel....you ll have to disable voodoo before flashing adryns super clean....ya gotta use the included stock kernel for now
Thanks Nit, I'll wait till I get home. I don't want people at work to hear the voodoo lady talking to me when I disable her.
More quick question - does the Super Clean version have swype and the pull down power bar in the notification bar?
yes and yes
Its not the latest beta of swype [2.15] its 2.8 but if you were on stock its newer than that
Anyone know why I cannot send text? I can receive them but I cannot send, well then appear to send but no one get them.
I have DJ05 baseband and I have tried both the regular 2.2 leak, and the super clean one. I have wiped data and cache, still nothing. I tried installing it again, but still nothing.
Any suggestions?
Any suggestions?
try the dl09 radio
im still on DI01, if i go straight to DL30 without going to Dl09 or DJ05, will my GPS be fixed on 2.2? or do i need to upgrade to DJ05/DL09 before i update to 2.2?
