Root [Q] Can root Evo 4G after being Flashed to boost?
Yhea that one, so just follow all the instructions from the HTCDev mothod all the way,but two things I don't get steps2,&3 Can u explain more of them, what is the step 2 How to get Recovery? how to install amon ra 2.3 recovery / how to install amon ra2.3 with android flasher,( which one i choose ) And step 3 flash the su file or flash a rom, ( stay on stock or flash a rom, which one )( cause if I flash a custom rom it will screw up the boost flash right?) is this really needed
Yhea that one, so just follow all the instructions from the HTCDev mothod all the way,but two things I don't get steps2,&3 Can u explain more of them, what is the step 2 How to get Recovery? And step 3 flash the su file or flash a rom,( cause if I flash a custom rom it will screw up the boost flash right?) is this really needed
you need to do both steps if you want to be fully rooted. step 2 is needed because you will need a recovery to flash the su zip file. it is not a rom so you should be ok. the su file is needed so that you can use root only apps like the wireless tethering app.
Ok I'm ready to root my phone all I need is some one to help me out after I do the root on my phone just in case my flashed boost phone won't work ,some one to help out to reflash it to boost ( just I case something go's wrong, hopefully nothing go's wrong ) and if so I do not own or know someone with a xp computer
i can help you rooting, but flashing your phone to boost should you loose the flash to boost, i'm not to sure on. here is the guide for flashing to boost: http://androidforums.com/evo-4g-all-things-root/460035-evo-4g-boost-mobile-guide-evo-3d.html i can try if you are having difficulties.
Ok I'm rooted by I can't figure how to wifi tether work, I can't make the wifi tether work at all please help I'm in the stock rom( it is root it )
ok you can either flash a custom rom that has the sprint hotspot hacked or you can use the wireless wifi tethering app found in this thread:http://androidforums.com/evo-4g-all...net-tethering-w-evo-4g-3g-wireless-wired.html.
here is also the sprint hot spot hacked:
[HotSpot Hack] Enable Hotspot on Gingerbread - xda-developers
and can you be more specific as to what is going on when you try to tether? also what are you using to tether?
Ok thanks got it working with the links provided
