Sliders can be changed on the free version also. But as there is only one kernel-anything you change in one app will just over ride the other.
Dont understand why you would still have the free version installed????
yeah, i ususally keep the actual apk, to my paid apps in a file on my sd card, so everytime i reflash another rom (which is a lot!!!) i have all my fav apps on my sd card awaiting installation via astro lolRight I know what your talking about.
Why you guys do that when you got titanium back up pro? It saves a lot of time. Instead of always clicking install it auto install it for you and have your recent set up. I highly recommend it.
:thumbup:
I use titanium. BUT titanium doesn't save apk's.
And if you switch ROM's a lot and you have an app saved as a backup but NOT installed, you will loose it unless you save the backups somewhere else and then put them back AFTER you have flashed your ROM.
I restore the data partitionIt saves the apps + data...restores your desktop exactly nowhere is was prior to flashing a new ROM :thumbup:
