When you update GAPPS, do you have to backup your system, apps, data?
Or is it an incremental backup that does not require reinstalling data?
Could someone provide me the order of steps to update GAPPS?
I am not sure if you have to wipe cache, davlik cache, system, etc.
Also, could you tell me the recommended procedure for updating CM10 ROM to the latest version?
Thanks alot for any help.
. Not much you can do to improve the signal / reception unfortunately. You can save a little battery by using wifi where available (it uses less juice than your cell radios do), turning down your screen brightness, avoiding using live wallpapers, etc.
