Root question bout myn's 2.2
lcallen80
if i want to add on something to myn's 2.2 do i have to do it like a flash for the rom? meaning starting all over with apps and things like that? or is there a way i can just download it the my card and flash it without wiping everything
Correct me if I'm wrong, but what you're suggesting is that you want to modify Myn's .zip file with something of your own design, then reflash that?
You can create your own zip files to flash, that'll only install files of your design.
If you are trying to add a theme or mod that specifically is compatible with the version of myns twopointtwo that you are running you would flash it just like a rom. And you wouldnt have to start over with apps...
Right. If you're talking about the flashable zip file provided by myn or some other developers, specifically made to modify myn's warm, all you need to do is flash them from recovery like a ROM, but don't wipe data. Just wipe cache/dalvik.
yes i jus want to add some more of his goodies. like that launcher pro..i like that.. so i can jus put it on my card and then flash it huh? and i my stuff will not be wiped out right?
No you will not be wiped. Easiest thing to do when flashing mods and various zips. Well first thing is make sure you have a current back up. I trust that you do. Select the option that says install zip from SD Card. Once it completes restart your phone and your finished. Its that simple. No nerve racking of loosing your data. Like Akazabam said just wipe dalvik cache before hand. DO NOT WHIPE DATA!.
Yep, ExSaint is right. Just make sure you do not have launcher pro installed before flashing myn's version. You must uninstall the market version, first, if you want that.
ok when im doing it from rom manager i see options to wipe data and cache... how do i only do dalivk and cache?
oooh ok how do i check that if stock launcher pro is installed?
...Are you using Launcher pro right now? If you never installed it, it's not there. If you're using it now, well...uninstall it :). Menu->settings->applications->manage applications. You'll find Launcher pro in the list of downloaded applications if you ever installed it.
have you downloaded it previously? You can look it up in the market and if it does not say "installed" then your golden. You would have had to download it at some point in time
ok i see that i have it installed but i want the one that gives you like 4 options at the bottom of the phone than the three. cuz right now i have the three that comes with RLS5...this rom is awesome tho ...i freaking love it...and ocnbrze i see that theme u posted i gotta load that up thats bad man!!!!!!!
