Root Questions about. 595 GB
SimsDelt
Android Expert
Just wanted to make sure that root was working on GB. 595 and that recovery was working right. Had heard bootstrap was borked somewhere. I know to use Droid 2 bootstrap. Was gonna load. 595 from Apex 2.0 but didn't want to leave Apex if. 595 had problems with bootstrap recovery.
everything works fine
There are some people that have ended up in a boot loop after trying to boot into recovery. It's mostly the people who installed the odexed version rather than the deodexed version. I went from Apex 2.0 to deodexed, rooted .595 without wiping data or cache.
Same here.
Me, too. Had a lot of problems with .595, actually, especially the battery life. Went back to .591 earlier today.
MIght be somethign else, I'm getting great battery life. At least on par with Apex, if not better.
Longest running time has been 2 days (10%) with a lot of pandora streaming over 3g
Anyone know why my calendar sync would break? it gives me an error saying it cannot sync right now...
anyone? I can put the com.android.calendar file I need in data/app (its not there) but I need someone to hit me up with the file... thanks...
maybe that isn't the fix... but I'd like it if someone could hit me up with what they think a fix could be.
I've been getting a lot of random reboots on this build. Not running anything weird, either.
Seems like my SMS and Email are getting stranger by the day, I will go for several hours and then get a bunch of them all at once, its not the sync settings, I've checked that already.
Well I decided to reflash .595 and then wipe data/cache. Just didn't want to reload everything... but I did and it all seems to be working well.
