brotherswing
Android Expert
You will need some kind of file explorer. Popular choices include File Expert, Androzip, ES File Explorer, and so on. Quite a few to chose from, but they all work in similar fashion. With the explorer, navigate to /system/bin (it will be obvious once you start) then look for su. Long press on it, you should see a context menu. Chose properties, and let us know what the permissions are. These directions are paraphrased, the actual steps, and names might be slightly different.
