Idunno
Wired Tether not working (velocity)
Been playing around with Velocity 1.0 for nearly two days straight now, I have worked out all my personal issues and the only thing left is wired tether. I have used the LG mobile update tool to download the latest USB drivers:
LGUnitedMobileDriver_S498CA22_WHQL_ML_Ver_2.2
LGSmartPhone_ModemlinkDUNDrive_WHQL_ML_Ver_1.0
LGWindowsMobile_USBDriver_WHQL_ML_Ver_1.0
I have installed/unintalled them in various orders, with and without the phone connected... and still no results.
I can mount for file transfer just fine, but when I fire up wired tether and start tethering I get the install hardware wizard looking for drivers for "LG android USB device". Upon further examination of the device manager I have 2 such devices that have issues (yellow !). Then when I stop tethering it goes back to normal, the two "LG android USB device"s disappear and I can mount without issue.
I have also tried tether before mount, and tether after mount with no results.
Does anybody know what is going on / have any suggestions? Please and thank you in advance.
Side note: Since I'm pretty sure the dev's are going to look at this at some point I just want to say thanks for the awesome rom and as soon as I'm not broke I will thank you properly with due donations.
Increasing maximum speaker volume?
I was curious if it is at all possible (either now or in future roms/apps) to increase the maximum speaker volume on our phones... for example when listening to music. I'm not talking window shattering volume, just some extra decibels to further enhance the listening experience.
If we can overclock our CPUs it seems that we should be able to squeeze some extra sound out of our speakers. Then again I don't even pretend to understand firmware/kernels/scripts or even linux for that matter so I'm asking anyone who does if this can be done.
Why are my quad scores so low?
My best was 903 and that was fresh install of Velocity 1.0 @ 787 mhz.
Now I restored my apps (only a few) and removed all the bloatware so you'd think it would balance out. Now i'm 519-540... I don't get it, why the sudden and DRASTIC drop?
