Root Quick PRL Swap in CM7 (updated 4/5)
Should I try a different PRL? I'm using a Motorola Triumph w/ CM7 on it. The PRL I'm trying to write is 11115.prl
What version of CM7?
It's possible, if you are running a *really* old version, that the prl number is hard coded in.
Meaning it's not displaying the actual prl in use, just a number.
So when you restore back to CM7, does it show the correct prl?
Sorry for the late reply. Yes, it shows 11115. I was using an old version of CM7 but when I flashed stock and changed it then flashed back it reported correctly.
I have since upgraded and am still reporting correctly.
Hello I was wondering if anyone could write out steps or link me a guide to how to completely do this I am just not sure what i need to download etc to do this. Thank you
http://androidforums.com/triumph-all-things-root/395533-big-difference-data-speeds.html#post3076107
If you have issues installing the drivers, as many do, this is invaluable:
http://androidforums.com/triumph-all-things-root/415058-extracted-triumph-adb-drivers.html
Thanks to wobblethehut for doing it.
