some roms have built in theme changers like miui, and cm7. i just flashed kings shift port that has the htc scenes and skins that you can choose from. something like what you are looking is usually built in to the rom. there is no app or program for that. for any themes or mods just head on over to xda: EVO 4G Themes and Apps - xda-developers. what modifications are you looking for?
there are a few luanchers that can be very customizable. launcher pro which i love and adw are the two that is most used. this is one t customed themed that granite did: http://androidforums.com/evo-4g-all-things-root/322488-super-mario-bros-theme.html. i also did a search for you over in xda for some myn's mods and themes. xda-developers -Myn's Search Results. hope that helps.
If you use launcher pro you loose the sense widgets. You can buy the full version of LP which has a lot of sense like widgets in it, or search for widgets in the market. LP also has different screen transitions you can choose from. And every icon is customizable in the dock. To change icons outside thee LP dock use folder organizer, it's free from the market.how does launcher pro look like ? i flashed the ginger launcher and dint like how it took the sense widgets and menues off so i took it off. thanks for the like xda devloper somtimes get difficutl to navigate sometimes. how do u know if u have the lastest themes, etc.?
What about metamorph? of course you still have to grab the metamorph themes but its a little simpler.
Also you can use the dsixda kitchen or the UOT, online kitchen (just google uot kitchen) to make flash zip of mods and add ons...
