Root Random Reboots in CM7
Mr_Coffee
Member
I am using TG's final release, and have been seeing an increase of random reboots? Any suggestions... I wiped and reinstalled last week.
First thing I'm gonna ask. Are you overclocked or undervolted? If you are you are either overclocked or undrvilted too much... if you are at stick settings then have you changed any settings or installed any apps?
when I first installed cm7 and the oc kernel it was by default over clocked to 1.9 GHz and would reboot as soon as the screen would turn on top fix I just turned phone on and wait about 5 minutes (turn sc)een off and after t hat hurry and got to settings-> cyanogenmod settings-> performance and set it to about 1.4-1.5GHz it's safe and it should work fine.
Left it as default, which is ON-DEMAND.
I just updated the kernel settings to Smartass. On a previous installation, I used the smartass setting.
We'll see if that makes a difference?
That must've been a long time ago? TG's later CM7 builds locked frequencies to 245-1024.
Also Tickerguy's CM7 doesn't allow frequency adjustments, so overclocking is not even possible. Try my TG-Reloaded ROM, which is more recent. And I have never had the phone randomly reboot except when I was trying to undervolt.
Random reboots are likely either hardware problems, or overheating due to a runaway app/service that runs in the background.
TG never had an overclock kernel. (I think) one of Mantera's first OC kernels defaulted to 1.9 at the top end. He fixed it back to default @ 1024 pretty quickly, in an early version.
I used to run TG's b.08 overclocked with Mantera's kernel. I assume that's the kernel he meant, since that was the first OC kernel that appeared for TG's builds.
Mine used to have reboot issues, back before OC kernels were available for our CM7. Some seemingly random, some fairly repeatable.
I had done full wipes on install.
Finally fixed it by doing full wipes/factory reset And then rebooting recovery And doing wipes/formats again, before installing CM7. Then, one at a time, restoring ONLY the apps that I actually used, one at a time, from Ti backup, with no data restored. Not sure what fixed it, but you know, searching the market for apps to do a particular job until you actually settle on one you like, we sometimes end up with several that do the same thing... Often thought that may have caused issues. May have been the double And triple wipes/formats surrounding at least one reboot of CWM recovery that fixed it.
