you can just leave it be and then flash the new bootloader /kernal and baseband zips from tbhmine is 2.3.320, so i installed the wrong SBF. lets try this again. brb
like i said i cant say 100 % since this is a leak but if you flash the 2.3.15 now you may end up with a paper weightwell the 2.3.15 I had didnt work. FML. any ideas where to get a legit one?
yes but not to worrie its painless and will get you up to speedhaha nice
sooo I have no choice then to use .320 and use TBH files
i did every one to be honest .....i downloaded them one by one (well i use dropbox)and flashed each one like a theme or rom ....install zip ,choose zip through bootstrap and i believe for one of them there were other instructions but just consult that link for the directionsok. what file do I install first and how do I do this. I am lost.
what do you mean back to .320 i thought thats what you said you were oni am halfway done flashing back to .320
of coursedoesnt bootstrap require root?
you have to update the patches i gave you first or you will never get another ota ever again since you flashed a leaked version .320I wanted to be unrooted and back to stock. what program can I use to root that will let me unroot?
Download z4root 1.3.0 for Android Free - z4root will root your device and enable you to supply system level access to applications that request it. - Softpediaunderstood, but what program can I use to root, that will allow me to unroot when I am up to date with .340
