ok if you accepted the .340 ota and then just now flashed the .320 sbf all you will need is the .340 system only sbf ... i would tell you to do it through the patches but your bootloader and kernal are already updated and if you do the system only sbf you will not have to unroot or re root or anythingok. i am now offically lost. do I still need to root? or is there a .340 sbf I can use?
i dont do it this way i just flash the sbfis the .340 system only sbf part of those TBH files? If so, which one? DO I need to rename it update.zip and then put it on my the root of my sd card then just boot into the default x recovery and select "apply/ update.zip"?
no problem man im trying ,there was a little confussion on my part lol and i apologize and i was praying you didnt flash the 2.3.15 lolThanks again for all your help. I cant thank you enough!
it should work just fineI did try to flash to 3.15 but it failed so I went back to.320 and that is where I am at now. Currently I am flashing the .340 sbf to my .320 phone so I am crossin my fingers n toes.
not at all necessary,im just happy to help and you can repay me by helping others as well ..glad we solved the problem.....just do me a favor and give me a readout of your kernal and bootloader numbers just to be sureAll fixed. I really cant thank you enough. do you have a paypal or something that I could possibly send you some money. I really am truly thankful.
bootloader is good but i have a different kernal and i thought for sure i was up to date let me checkkernal-2.6.32.9-gca645b6
w30471@il93lnxdroid08 #1
Bootloader-30.04
Bootloader-30.04
should just be able to select unrootdo you know how to unroot from z4root?
