triggaslim
can anybody help me get icecream sandwich on my lg connect pleaz
okay thank u is the lg connect newer than the lg esteem just wondering because i just got it i couldnt decide i hate 2 do anyminymity moe type it was a hard decission
I am wondering what typing has to do with ICS. There are many different keyboards available to use that pretty much work on any Android. SWYPE is already built in to the Connect. Also give SwiftKey a look. Then there is the Gingerbread keyboard from the market that seems to be the best for battery life.
I think he's saying he had to do an inny minnie miny moe when picking between the esteem and connect.
What exactly would the benefit be with ICS on a smartphone as opposed to a Tablet ? In other words why would you want to get ICS on your Connect 4G ?
Better all around performance. Exclusive applications (youtube chrome .ect) its multitasking improved. The whole thing is skinned very nice.
One thing that has not been mentioned between the connect and the esteem, well the connect can do voice and data on 4G while the esteem cannot unless your on wifi which means ur not on 4G anyways.
Does this mean that you can check something on the Internet or view received Email Images while on a call on the Connect ?
