Realtime Traffic & Speed Cams
New release on the market (2010-09-01) :
Version 1.0.48a Code Version 65: For Android 1.6 and earlier:
  • Evolution: Version 1.0.47a port
  • Evolution: Add option to specify if phone should be wake up on alerts or not
  • Evolution: Add option to not be alerted for events on the other side
  • Improvement: Few preferences options required the service to be restarted. This is now not useful any more (mute, vibrate and brind to front)
  • Improvement: Reduce bandwidth and battery consumption
  • Improvement: Phone wakeup on alert wasn't always performed
  • Improvement: Alert sound may not be played or partially
As this software is free it's success only depends on comments on the market. Can you rate and comment my app on the market?
New release on the market (2010-09-09) :
Version 1.0.49b Code Version 66: For any Android version having standard screen size:
  • Evolution: Version 1.0.48a port
  • Evolution: Few default options in preferences have been changed ("Follow Me" and "Traffic Info Layer")
  • Fix: Addresses where showing schools most of the time
New release on the market (2010-09-14) :
Version 1.0.50c Code Version 67: For Android 1.6 and earlier:
  • Evolution: Version 1.0.49 port
  • Evolution: Add speed trap and accident notification from notification bar to be able notify from any other application
  • Evolution: Add an Auto Launch Plug-in. When connecting USB cable Real Time Traffic can be automatically launched. This plug-in is available on the Market as "Real Time Traffic Auto Launch".
Is it possible to have the map rotate as you drive so you are always going "UP" on the screen like Google maps does? I love this app!
For the moment it's not possible but tis feature is in the pipe and has to be carefully optimized to not drain the battery even if it's charging ;-)
If you like my application please rate and comment it on the market to tell the other what you think about it ;-)
Mail me if you have a problem of suggestion
So is this app popular enough yet to give accurate results in a decently populated area?
Also a search on the market for "realtime traffic" only brings up Traffic USA for Android 1.5 with 2 stars...
The best way to know is to try it ;-)
But as far as I can see my application is pretty well used world wide if you have look to Real Time Traffic you can see where users are ;-)
New release on the market (2010-09-20) :
Version 1.0.51c Code Version 72:
  • Evolution: Version 1.0.50c port
  • Evolution: Add "Move Application to SD" support
  • Improvement: Loading preferences could be long according the number of installed applications
  • Improvement: The identification of the road you're driving has been improved
  • Improvement: Now optimized for any screen size
New release on the market (2010-09-23) :
Real Time Traffic Auto Launch Plugin Update
Version 1.0.1b Code Version 2:
  • Improvement: Application could be long to be launched when you installed many applications on your phone (over 100)
New release on the market (2010-09-24) :
Version 1.0.52e Code Version 69: For Android 1.6 and earlier:
  • Evolution: Version 1.0.51c port
  • Fix: Address displayed on startup may be wrong
New release on the market (2010-03-22) :
Version 1.0.21d Code Version 38: For any Android version having standard screen size:
  • Evolution: You can now display the driving route between your position and the destination. This is the first step before simple navigation in the application.
  • Evolution: You can now switch from "Users" to "Average Speed" to "Distance" by touching the items.
  • Improvement: Different layers are now properly displayed. Trafic Info is not any more over speedcams, accident and you location cursor.
  • Improvement: Reduce load time and memory use.
  • Fix: Default language could be set back to French. Language is set to Android language by default.
What is the name of the app?
New release on the market (2010-09-30) :
Version 1.0.53a Code Version 74:
  • Evolution: Version 1.0.52e port
  • Evolution: Add reference to Glob and http://g-lob.com in application
  • Evolution: Prepare for plugins generalisation
  • Improvement: Better address lookup
New release on the market (2010-10-05) :
Version 1.0.54b Code Version 75: For Android >= 1.6 Only (2010-10-05)
  • Evolution: Version 1.0.53a port
  • Evolution: It's now possible to use headset media buttons to notify events:
    • Previous Song button (short press) : Notify accident on my side
    • Previous Song button (longpress) : Notify accident on the other side
    • Next Song button (short press) : Notify speed trap on my side
    • Next Song button (longpress) : Notify speed trap on the other side
  • Evolution: It's now possible to disable notification bar shortcuts from preferences
  • Evolution: Add Glob and http://g-lob.com in Google Earth export files
  • Evolution: Add a link to maket to quote the application
  • Evolution: The Beta Tester number is now the VIP Number
  • Improvement: Alerts sounds may not be played up to the end.
New release on the market (2010-10-12) :
Version 1.0.2a Code Version 3:
  • Evolution: Application ask you to go to market to install any version of "Real Time Traffic - Glob" if none is installed on your phone
  • Evolution: If the two versions of "Real Time Traffic - Glob" are installed, the application launches the most recent version
New release on the market (2010-10-15) :
Version 1.0.55c Code Version 76: For Android >= 1.6 Only (2010-10-15)
  • Evolution: Version 1.0.54b port
  • Evolution: Better addresses refreshments
  • Evolution: Prepared for additional Traffic Info layers
  • Evolution: Prepared for displaying number of users on your street
  • Improvement: Better speed refresh
  • Fix: Icons on the map may not be displayed if update was triggered when application didn't have the focus
  • Fix: Addresses didn't update
New release on the market (2010-10-19) :
Version 1.0.56a Code Version 77: For Android >= 1.6 Only
  • Evolution: Version 1.0.55c port
  • Evolution: Application title changes to "Glob - Real Time Traffic"
  • Improvement: The "Other Side" checkboox is now also sensitive on the label and not only the checkbox
New release on the market (2010-10-29) :
Version 1.0.57b Code Version 77: For any Android version having standard screen size:
  • Evolution: Version 1.0.56a port
  • Improvement: Map centered on last known location on startup
  • Improvement: Better beahviour on Galaxy S
I use and like this application. The only negative thing I can say about it is that the top information bar takes up too much screen space and the screen doesn't center enough when traveling north. This means there is very little of the map showing to the north. Also, when a person is traveling north, it is very hard to see what is ahead because the "Your Location icon" might be all the way up to the status bar before it gets centered in the screen again.
Is it possible to hide the status screen (user selected), or make it smaller, or center the your position icon more frequently?
Thanks,
Have you tried going to Menu > Preferences > Follow me Frame Size and changing it to a smaller percentage?
Yes it's the aim of this preference. You can ask the cursor to stay in this frame expressed in screen size percentage.
If you feel the notification bar and title bar takes too much place on your screen you can also play with Menu > Preferences > Progress Bar and Notification bar options.
Unfortunately it's pretty hard to make the map rotate as it takes too much CPU and too much network accesses and by th way reduce battery life
Thanks everyone. I made the suggested changes and also found so other settings that helped show more screen too (like hiding Street Names).
I think this will work much better.
On a side note, how long does the collaborative traffic display? It seems like it shows a persons track for perhaps an hour or so. Is that right?
Collaborative Traffic is erased after 30 minutes.
