Sleepingsirens
What do you guys recommend for a good, smooth and fast launcher/locker? Thanks!
same here go launcher pro and ADW are a bit to big for me but idk thats just me holo is super lite 1.75mb and if you going to do holo launcher and locker then just go all the way and do the Ultimate ICS theme that is what i got running and its smooth and looks nice heres the link if you interested(it only works on cm7 btw)Holo launcher\locker here.
ok, here's a really non standard suggestion...
THE smallest, fastest launcher available is Lightning Launcher. I've been playing with it lately. Less than 60Kb download, and uses much less memory than even zeam. It uses a separately downloaded app to configure, so it's not part of the main launcher while in use.
It's really different so you may not like it, but you can do stuff like rotate widgets to odd angles, and use any icon our name for any app. amazingly small and fast.
I also use Wave Launcher that mancow turned me on to. you can instantly bring up its launcher or recently used app on top of any screen or running app.
These two make a really small fast combination.
Probably not for everyone though.
I don't lock my phone, just certain apps, like email, photos, and stuff that messes with system settings. to do this I use Visidon app lock. Uses front camera for face recognition, so CM9 is out.
you can use it in lock screen mode too. has a pin for low light situations, but it's fast once you train it correctly.
That's my current configuration and I'm digging it
I went with your idea of lightning launcher, and boy is it different! How can i add a wallpaper to it? nothing im trying is working
while on your home screen, hit the menu button, then Customize and scroll down to wallpaper.
The setup is really different... took me some fiddling to really figure it out.
