Switching Recoveries
speaking of recovery i would really recommend that everyone switch to amon ra 2.3. it is a much better recovery then clockwork mod. you can get the recovery here:PC36IMG RA 2.3.zip
here are the instructions:
1.download the file.
2.rename the file by erasing the "_RA_2.3" part of the name so that it is only named PC36IMG. make sure not to add ".zip" to the name as windows hides extensions.
3.transfer the file to the root (that means not in any folder) of the sd card.
4.power off (you most likely need to uncheck fastboot. settings/apps/uncheck fastboot.) then press and hold power+vol down.
5.hboot should see the file and select yes to update.
6.select no to reboot because we want to go into recovery and make a nandroid backup.
7.select recovery.
8.select backup and restore and select backup
9. select the first three and wimax. the other partitions do not need to be backed up. always keep one nandroid backup with wimax keys backed up on your computer.
10.now you can reboot.
11.using a file manager of some sort or even through your computer via usb, you should rename or delete the PC36IMG file on your card. otherwise you will be asked to update every time you go to the hboot screen. you do not need that file any more.
I think we definitely need a better explanation of what you're trying to do. I have no idea what Android Flasher is.Trying to make a custom recovery before flashing a rom,keep getting the phone with red error triangle,android flasher said it flashed but also mention possible missing drivers what am i missing ore needing to do
Android FlasherI think we definitely need a better explanation of what you're trying to do. I have no idea what Android Flasher is.
If you want to install a custom recovery, you can do it in the bootloader as Rxpert lists above. It's very easy to install.
Ah, well ok. Guess now I know
Not so easy with the unlocked bootloader from HTC with the latest OTA, though. Android Flasher is easier than manually typing fastboot commands at a command prompt.Ah, well ok. Guess now I know
It's so easy to do in the bootloader that I never looked for an alternative way to do it.
Agreed. But one thing to think about - if HTC allows for unlocked bootloaders on all their new devices (as they have been doing), you'll have to use the HTCDev method to unlock your new device. It might be a good time to try it out on your EVO to get used to how it's done, so you won't have any worries about unlocking in the future. Just something to think aboutGood to know. Hopefully I never have to mess with it. I'd like for my Evo to last long enough for me to get my hands on a quad core.
.Agreed. But one thing to think about - if HTC allows for unlocked bootloaders on all their new devices (as they have been doing), you'll have to use the HTCDev method to unlock your new device. It might be a good time to try it out on your EVO to get used to how it's done, so you won't have any worries about unlocking in the future. Just something to think about.
Yes, you need to flash a custom recovery next. Without that, you can't get root access.Yeah I am trying to flash a recovery after the htc unlocker,I did eventually remember to extract the img file,but then I got lost my internet kept going out which really messed up my process.I haven't tried the listed way yet because i couldnt get the file at first,if he's up for it i will try today and thanks for the help,I'm not sure what info to give to be more specific
Bootloader comes up but I'm guessing since I havent created the custom recovery its nothing there wheb i go to recovery?
i got to the hboot,it said update failed i tried to go into recovery it gave me the same picture phone with error triangle.,should i extract the files before dropping them onto the sdcard or leave it zippedFirst of all, if you''re trying to switch recoveries I would suggest doing it manually in H-boot.
Instructions can be found here:
http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html
