2d 9h 25m 26s now at 23%
Really amazing result
@ togger161: Could you please share battery usage screenshot with such scenario? How many minutes your screen was on during that time?
By the way, how often should I calabrate the battery, and what would the best method (tried and tested!) To do it? Read all kinds of nonsense. Any thoughts?
Ta.
Anyone? Just curious. It's a new battery, never been calibrated before.
I know the process (correct me if I'm wrong)
-Charge to 100% while the phone is on (till thon led is green)
-Unplug, switch the phone off
-Plug the charger back in, and (if the led goes all orange and whatnot) wait until the led goes all green again.
-Unplug and boot into recovery
-Re-calibrate the battery
-Robert is your mammys brother
Is that right?
And how often should this be done?
Thanks, you lovely folks.
Only if you're having really odd battery behaviour. It's not something that needs to be done regularly
It depends on how busy I am at work and how slow this forum is when I am travelling to and from work.
Its hard to put a typical day down. It can be anywhere between 1.5 Hours and 2.75 Hours. Rarely above that but sometimes I can get upto and over 3 hours.
I dont really watch videos or anything. I generally use it for forum use.
Using GV 2.2 myself, and just installed Juice Defender. The downside is that now it takes 10sec to connect to 3g, and the connection is off unless I switch on the screen (
