[REFERENCE] All things reference thread
ninadchaudhari
What's up !
I found one at the Micromax A70 hence created one for A75 .
Facebook Official Group for Micromax A75 -
Every one is requested to join this :)
http://androidforums.com/micromax-a75/513493-facebook-group-micromax-a75-users.html
How to flash anything in Micromax A75 -
http://androidforums.com/micromax-a75/497925-how-flash-your-a75.html
Stock Dump[Default MMx Firmware] in the above mentioned files itself .
Show your creativity here -
http://androidforums.com/micromax-a75/513750-post-your-homescreens-here.html
Install ADB drivers for your phone -
http://androidforums.com/micromax-a75/513945-easiest-way-install-drivers.html
Original Spny Xperia S launcher for any GB device
http://androidforums.com/micromax-a75/523864-sony-xperia-s-home-launcher.html
Root your Phone [[ Sticky in All things root guide ]] --
http://androidforums.com/a75-all-things-root/541990-working-method-root-a75.html
Alternate Way :
http://androidforums.com/a75-all-things-root/502084-working-how-root-micromax-a75.html
Which ROM to Choose
http://androidforums.com/a75-all-things-root/524770-rom-chose.html
Improve your device performance , -- Over-clocking
http://androidforums.com/a75-all-things-root/524515-working-overclocking-micromax-a75-mt6573.html
Tutorial to install/Flash flash-able ZIPs
Way to fix permissions for all internal files after root -
Now not required , everything pre-done in ROOT5 ROM
http://androidforums.com/a75-all-things-root/506016-how-fix-wifi-other-stuff-rooted-phones.html
List of all Compatible Games for A75 -
http://androidforums.com/micromax-a75/487851-hd-3d-games-compatible.html
Setup Static IP for Android -
http://androidforums.com/micromax-a75/503213-set-up-static-ip.html
Modded Boot image
http://androidforums.com/a75-all-th...t-img-adobe-flash-working-init-d-support.html
CWM based Custom Recovery
ClockworkMod Recovery 5
Changing lock-screen view
Build.prop Tweak for Changed lock-screen
ROMS :
UB-A75-1 [Ultimate Brain -A75 -1] -
http://androidforums.com/a75-all-things-root/506827-rom-ub-a75-1-a75.html
UB-A75-2
UB-A75-2
Indiedevers - JetMOD 3.0
JetMOD 3
SperiA A75
SperiA A75
ADProgrammer
AD Programmer
ADProgrammer 3
AD Programmer 3
As progress continues , I will keep this thread updated !
Please PM me if you find this thread outdated !
It is good for future development ..
post if i have missed something !
ninadchaudhari,
I've stickied this per your request.
Good stuff. by the way :).
Be sure to let karandpr know about the good root-related links you've got above for inclusion in the all-things-root guide if you haven't already.
Cheers!
Hello Ninad,first of all thanks from me
want to know is there any thing new in A75-Root than UB-A75-1_v2??
I have already rooted previously with UB-A75-1_v2.
Please help
IF i previously rooted with UB-A75-1_v2,
Is there any thing to do better???
I am quite satisfied with UB-A75-1_v2
IS there any thing to change boot up screen???
I dont know how to use--- Splash changer by Ninad.
Please help
What is the difference between rooting and modding??
And one more question,after modding with UB-A75-1_v2 Can I unstall youtube,google map,market??
The unstall option is faded in application manager...
Sure you can install everything
For what is Root refer to the FAQ thread
and Modding is like Changing and adding stuff got better performance and Battery
hi everyone...:wavey: Lets start a thread where users can...u noe give feedbacks :rolleyes:, post bugs ;), DEVs can share challanges nd concentrate on parts they r good at :D, learners can have opportunity to learn :p , and maybe a section where we can post our demands, n feature requsts:p:p, so that u keep in mind whats important as u develop ur rom...u noe...makes life easier ( y did no one start it b4 :eek: ) Just asking ninad if it is reqd or else it will b just a space consumer !:p:p
For feedback, and bugs you can sure post in the same ROM thread ;)
for a new general bug you can create a new thread :p
And if a developer, choses to port a ROM , sure it is highly recommended that the developer can share the progress here ! so that everyone can get to the stuff and see if it works ;)
for demenads and requests, sure you can start a new thread ;) else, you can use this thread for general queries or comments :p
if anything you feel you can sure create a new thread for that :)
even PM any one here :D
btw,
nothing is just a space consumer !! :rolleyes: :D:D
