Root [Release] Android 2.2 Froyo for the Droid X
D13
Android Expert
Prerequisites-
1. You have to be stock with no themes
2.If you have bootstrap recovery you need to either update it in the market or follow the directions later on to still get the update to pass
3.If you want to keep root then you must move su in /system/bin to xbin
How-to in adb
"adb shell"
"su"
"mount -o remount,rw -t yaffs2 /dev/mtd/mtdblock4 /system"
"mv /system/bin/su /system/xbin"
If you update your bootstrap recovery then put this file on your sdcard and install it
http://bit.ly/9FK8h1
If you don't have the updated version of bootstrap then you can either flash an sbf or delete the logwrapper
With an sbf
-Flash the sbf
-re-root with your method of choice, I used universal androot http://androidforums.com/all-things-root-droid-x/151214-app-universalandroot-1-click-root.html
-In adb run
"adb shell"
"su"
-Then put the update.zip,at the bottom of this post, on your sdcard
-boot into recovery
-apply update.zip
Deleting the logwrapper
UNINSTALL the Recovery APK in Settings, Applications
Reboot
Run "adb shell"
Run "su"
Run "mount -o remount,rw /dev/block/mmcblk1p21 /system"
Run "cp /system/bin/logwrapper.bin /system/bin/logwrapper"
Reboot
You can also do it with root explorer
Find logwrapper and delete it
Then find logwrapper.bin and rename it to logwrapper
Then you should be able to boot into recovery and install the update without flashing the sbf
update.zip
Rsd lite if anyone needs it
_mrbirdman_
i love the taste of froyo in the morning...it tastes like...victory.
5 minutes ago via web
P3Droid
okay tell everyone to back down a little....we have 15k people trying to get it at once....only 8k can be online at once
haha thats funny
Don't get why he chose to make you register to download it. Just to increase the user count of the website? I mean, if people register just to download it but never had any inclination to do so in the past, they would just register, download it, and never touch the website again, leaving a dead user record on the forum. (Unless they needed to log on again for another download...)
It's kind of an ego stroke thing to do that, should have just released it via MegaUpload link or something so everybody could get it. If people wanted to register to say thanks or something afterward, they would have.
EDIT: Nevermind, just ate my words, he just posted it on Mediafire. :P
Maybe a good case for not releasing it during peak traffic time, and instead releasing it at 2AM or something to spread the release out.
Not suprising, but extremely dissapointing.
