Hi all,
Some of you may know me from the LG Spectrum forums. Here is a method for returning to stock that should NOT erase your IMEI and is much easier then setting up for flashing .tot .
NOTE : I do not own a LG OE, but the instructions should still work. If anyone runs into an issue, please let me know and I will work with you to correct it.
EDIT: This method is currently on hold until I find a copy of the .cab that actually contains the .dll needed to flash it. It should have been inside the cab file, but it was not.
Here is instructions on how to flash a new firmware. If you do something wrong, you will brick your phone, especially if it's during the final steps as flashing the cab actually deletes your recovery partition before flashing the new one.
Tools needed:
KP500 (http://androidfiles....ls/LG_Tools.zip) - Personally hosted, so please don't hammer the site
LG Update tool from LG site (also includes link for drivers) http://www.lg.com/us/support-mobile/lg-LGVM696#software
.cab file containing your firmware
V4_01: http://csmg.lgmobile.com:9002/swdata/WEBSW/LGVM696/AVGMBK/VM696ZV4_01/VM696ZV4_01.S4_01.P61007.cab
An internet connection on the PC you are working from. The LG tool needs an internet connection while flashing the phone or it will fail. If you have a firewall asking if you want to let the LG Tool talk to the internet, let it.
Instructions:
Charge your battery to full, not just 80% or so.
Run the driver package and let it run its course. It will appear as thou nothing is happening for about 30 seconds, then the installer will finish running. Then set phone to Debug mode and make sure all additional drivers install correctly. If you have adb on your PC, you can test your connection buy running ADB shell and seeing if your phone connects correctly
Go into your Windows Device Manager and disable the device under Modems -> LGE AndroidNet for USB Modem
Remove your battery and remove your memory card.
Reboot your phone in "Download Mode" (re-insert your battery and replace the back plate. Hold down vol up + vol down. Plug in usb cable while holding both buttons.)
I highly recommend using the official cable that came with the phone when doing a flash and not being on and USB hubs.
Extract KP500 tool into a directory (i.e. C:\KP500)
Move your .cab file to the same directory
Run your KP500 file as administrator
Choose I "Flash with assistance (file .cab)
Phone Model = VM696
Input the full path to your cab file including .CAB at the end (i.e. C:\KP500\VM696ZV4_01.S4_01.P61007.cab)
Input the full file name of your cab (aka version) without the Cab (i.e. VM696ZV4_01.S4_01.P61007)
Watch as the LG update tool pops up.
It will most likely tell you that your phone is disconnected. This is normal and to be expected
Click Restart.
It will find your phone and go thru extracting the cab file and then extracting a .bin file.
At this point if you did something wrong with driver setup or not disabling the modem driver, you will get a page error. If you did it right, you will get a percentage indicator that goes past 15%. Every so often a message will go by about "model dll message not found". This is normal.
Wait for your phone to finish flashing and let it reboot on its own. I did not do a factory reset and everything came back as it was, but with a new firmware version. You may wish to do a factory reset just to be safe.
Enjoy the fact that you can now recover your phone if you do something wrong (in most cases)
Tools needed:
Instructions:
Phone Model = VM696
Click Restart.
I've done it before for the Optimus V.
