GameTheory
Android Expert
Return to stock ZVD, the easy way.
Thanks to LDrifta for the stock zvd zip.
All I did was make easy, step by step instructions.
I tried this myself on my personal phone and made this guide along the way. I can confirm that this works 100% .
I am not responsible for your device..... or health. LOL
*Must be on a ZVD based rom to use this guide*
Guide:
1. Download stock zvd zip to your computer (link at bottom)
2. Unzip the file and you will get a folder named: zvd_stock (drag it to your desktop, do not rename it)
3. Plug your phone to computer and switch it to mass storage and allow few seconds to mount
4. In windows go to start menu and open my computer - next open removable disk - next open clockworkmod - next open backup (leave this folder open)
5. Now drag the zvd_stock folder that we placed on your desktop to the folder we left open (wait till it's finished copying over)
6. Now unplug phone from computer and plug it to power outlet instead and boot phone into recovery and make a backup just in case
7. Then wipe data - next wipe cache - next wipe dalvik cache
8. Now go to backup and restore - next go to restore - now click on zvd_stock and flash this
9. Once process is finished, reboot
10. The first time you boot you may have trouble with data, you may notice your 4G and signal bars are greyed (don't panic) just put your phone in airplane mode and and wait 10 seconds then take back off airplane mode and that should work. (worked for me)
11. You should now be on a completely stock phone only with root. If you wish to also un-root, see next post below.
Guys I
Guide:
Guys I
