mxsjw
Android Expert
Where can I get these launcher icons?
http://androidforums.com/android-themes/140958-icons-tallmin-updated.html
So what needs to be changed in what xml files (or any other files) to get the 10 battery working? I already have the 10% increment png files that I want to use.
Shekels huh? Thanks. Honestly, I don't need the cash AND I'm no dev. I'm sure some DX dev somewhere needs the Shekels more.
Hope it works (I run it all night and no FC's or weird text that I could see).
The mod works fine for me, no PC's, I can see text in buttons, now, etc. I hope you didn't take my offer as an insult. I like to show my gratitude for folks' work by paying for it. Thanks for sharing your good work!
Steven
) so I'm not in need of donations. It's just that a lot of DEVs seem to be out of work and this little project gave me an idea of how much work they put in.yes, aaaaaaaaaaaaaaaaaaand yes.![]()
I just installed via Rom Manager. Is this the entire theme for Revo? Or Just the Info bar? I thought I was modding just the battery file, previously running NexTheme(ApeX). But it appears now I'm running Revo. Do I have a hybrid or is this the full Revo Theme?
Do you have to be running Apex for this work, or can you just be using the REVOlution theme?
Yes you must have ApeX installed. Best thing to do is to install ApeX then Revo then the Mod.
Shoot, thanks. I had apex installed but had to ditch it. It's an awesome rom, it just wasn't for me. Really wanted this circle battery.
