starkraving
Android Expert
Decompiled frameworks from both aokp and cm9 no differences. May be in the mms apk itself.
Got it!
Verified send and receive success using native Messaging app. :thumbup:
These small issues with Torch and MMS aside, I am finding this AOKP ROM more stable, configurable and intuitive than the CM9 ROM.
we still have to use that app to get the led working right?
Yes if you're referring to the soft keys for notifications? If/when he can enable bln support in the kernel you will no longer need it.
Got it!
Agreed. If he ever builds a full JB PA ROM you guys are in for a treat.
Is PA > AOKP? AOKP > CM at least on my OE right now...
PA is sick
In the meantime, if phenomx4 can work out the small # of bugs found so far in this AOKP ROM, that would be awesome!
I don't think I'll go back to CM9 due to the problems I experienced.This doesn't give me much confidence in CM10 either. The # of FCs and issues AOKP reduced over CM9 is 100%. We shall see...
\m/
Can someone post a link for the wifi tether app I can't find it in the playstore
You have the same settings? I'm still only sending.
Just able to send in native. But textsecure sends recieves...
Are these screen shots from the latest AOKP build for the LG Optimus Elite? If so, where are these settings? These normally are located under Settings --> Wireless & networks --> Mobile Data, however, I don't see any menu item to add an APN.
Generic Virgin settings:
<apn type="mms" apn="0" mnc="490" mcc="311" carrier="Virgin Mobile US" mmsport="81" mmsproxy="205.239.233.136" mmsc="http://mmsc.vmobl.com:8088/mms?" port=""/>
Opened Voice Dialer
spoke "open apns"
Menu
Create new
Added info from Leslie's post
Use the screen shots to guide you and there you go. Be sure to choose Save from the menu before exiting the setup screen.
Never used Voice Dialer before. Interesting that you can use it to set up the phone.
Anyway, works now. Appreciate the clarification.
