just wanted to let you know that after installing the last "testboot.zip' from 10/16, almost all of my lag issues have been cured, and the system handling memory seems awesome, I seem to have more memory free more often, it feels quicker & just all around smoother to me, i do still have the slight screen tears as others have mentioned, thanx for hard work
I've also experienced almost no lag issues. I also do not experience any of the screen issues others are reporting. Granted, I do not use the stock keyboard (use Swiftkey) and I do not use stock lockscreen (use Widget Locker).
The only issue I currently have is the SMS messages do not split automatically, therefore, any text message over 160 doesn't send.
I cannot reproduce the 160 split issue. In fact I just sent a test message that split itself into 5 parts. You sure you have SMS split set in the messenger menu?
Don't see that setting.
Has anyone else run into this issue... my display brightness will not change when I try to change it, I have to wait until it locks or sleeps or manually lock it..then its changed when I wake it again whats weird is that it does that with ANY app or widget I try to use I've downloaded tons of apps and Widgets to test and its same with all of them... any ideas???
after looking back thru the comments I noticed that most users don't have any problems with the MMS working on this AOKP ICS rom. It worked fine for me on the CM9 version, but when I changed over to this AOKP version my picture messaging stopped working all together. I've tried the MMS that comes with this Rom, I have also installed other MMS apk's to test with no luck.
It just won't send a picture message at all. It just sits, saying "Sending" and that's about it.
I was hoping that someone could give me some hints to how I can fix this, or is there another MMS.apk I can install that will get the picture messaging working? Any help is greatly appreciated....
I noticed this as well. MMS does not work on Jelly Bean AOKP either. Please fix on both versions.
Works fine here make sure your apns are set correctly. I've had no issues with either CM10 or JB MMS. (Virgin Mobile)
Open your voice dialer app.
Say "open apns"
Then make sure your apn 0 look like this...
If not edit it in the settings options. Save then exit.
