Root [ROM][4.0.4][BETA] AOKP ICS for Virgin Mobile and Sprint 10/3/2013
Performance seems better! But graphical tearing is still present for me. Good job though. Switching back to the 9/29 img until the graphical issues are sorted.
Instagram error
Tried to get logs and screen shots. There's nothing discernible in the logs and the screen shot is impossible .:confused:
I'm having the same problem. Although side note, YouTube and Facebook are fixed completely with the new kernel and they work fine on my phone
Updating the adreno gpu with the new ics 220 drivers sorts it out.
Mount system and flash in recovery.
Download:
https://db.tt/5hOwEoAq
Phenom feel free to add this fix to the OP till you add it to the rom. Cheers guys :)
Disregard it started again...:mad:
Download:
Okay thanks. Someone try them out for me. I'll use these in cm9 as well if someone can confirm this fixes the problem
The updated drivers helped. But the issue returned after a while. Do you recall if vsync is enabled on this kernel? If so that could be the issue. While vsync on is awesome for bench marks (and performance if the device can handle it.) It isn't necessarily good for mdpi devices with smaller processors/gpus.
Again the fix lasted for a bit then it started again. Almost feels like deterioration... :mad: grrr , OK what I did notice in developer options that forcing 2G rendering is helping.
