Root [ROM][4.0.4][BETA] AOKP ICS for Virgin Mobile and Sprint 10/3/2013
AOKP ICS mods coming soon...:cool:
These are optional mods separate from the AOKP ROM, yes?
phenomx4, are you planning any more AOKP ROM updates? Or, have you moved on to releasing a stable ParanoidAndroid JB ROM?
Thx!
Thx!
Still working on CM9 and AOKP. Would love to do PA but sometime in the future.
Been running this Rom for a day now, and all I can say is....... THANK YOU PHENOM! Great job man. You keep our Optimus 's running like new phones. No bugs to report, smooth as silk, just wanted to stop by and say Thanks. :)
Anyone else occasionally have to reboot your phones to hear phone calls. I believe cm9 used to have this problem other than that and sometimes when I press not hold the back button it will kill the app lastly sometimes when I get calls the phone will lag so much...but overall aokp runs so much better than cm9 I have high hopes for this phone and man u have some serious f-ing talent keep it up man!!
Hmm. I've never encountered this. Next time take a log. I'm going to open a bug tracker soon.
I've had some strange issues with ringtones. I have set a default ringtone, but I also set a separate ringtone for a contact. Sometimes the default ringtone plays instead of the contact ringtone. Sometimes the correct contact ringtone plays. Other times the default ringtone starts to play, but then the contact ringtone plays.
Anyone else experience this? I haven't yet nailed down a catlog, but I'll keep trying.
Just experienced this problem today. If it were not for the fact I had the phone out in my hand, I would have missed the call (a very important one at that).
Honeycomb lock isn't showing up once I switch. Wake to unlock, menu unlock aren't working either. Will get you logs after work.
Honeycomb lockscreen Seems to be working fine here and where is wake to unlock located ? And I believe menu unlock doesn't work because it's disabled in the framework.
Flash went smooth, but it appears the phone is having problems connecting to Google. The data icons are gray, not blue, and I cannot connect to Play store.
Errors CatLogged:
[HIGH]Failed to find provider into for com.google.android.gsf.gservices[/HIGH]
Finsky is also throwing exceptions:
[HIGH]ErrorStrings.get: No specific error message for: com.android.volley.ParseError: java.lang.RuntimeException: java.lang.NullPointerException: expected receiver of type com.google.android.finsky.protos.Response$Payload, but got null[/HIGH]
Errors CatLogged:
OK, So it appears from other warnings that I have to confirm Google credentials. i.e. I think I have to remove my Google account and re-add it to re-authenticate after flashing. Is this a standard operating procedure after a flash update? Is there a simpler way to re-enter Google account settings?
Removing Google account and re-adding results in a blank screen with adding the account. Reboot doesn't fix it either. :(
