LowEndGeek
Android Expert
That sucks. Have you tried restoring a nandroid?
From where? Everything is gone now. I rebooted and the entire SD is gone. Plus my phone is dying.
I can't even download another rom cause there is nowhere for it to go.
My sd card is suddenly working, Pictures & music is all thereThe system is showing the sd as unmounted, when I try to mount it says damaged sd card. I even tried to format it and that didn't work
Does your sd card mount in recovery?
That happens when the media scanner hasn't finish scanning the SD cards.My sd card is suddenly working, Pictures & music is all there
Hm. Do you mind posting a logcat on pastebin?
I'm getting some nasty lag for about 30 seconds when I wake it up from sleep. I'm not using the live wallpaper and I'm using Interactive at 1612 max and I just noticed 122 min. That's probably my problem. I'll bump it up to 245. We'll see how that works. I'm also using surface dithering whatever the hell that is. I'll try turning that off.
What filesystem is your sd card?This is the best I can do https://docs.google.com/file/d/0B82boW6WyAKkQW5kcnVZcFBkOXc/edit?usp=drive_web
One thing I'd like to say is make sure everything gets wiped, including /data. I like to wipe data/factory reset, /system, cache and davlik, all at least 2-3 times. To get any junk that is left over from gingerbread. And don't restore app data when using titanium, and/or don't advance restore data. Especially since this is gingerbread to ics, and the framework is so different. And don't use giantpune's gingerbread kernel.
I hope this clears some issues up, or stops some irrelevant bug reports.
Tethering doesn't seem to work, ad-hoc or hotspot.
Hey im having a few problem with storage
Try to download from dolphin - An SD card is required to download AmazonApps-release.apk
Restore apps with TiBu - The current backup location ("/mnt/sdcard/TitaniumBackup") cannot be accessed
Hooking phone up to pc via usb - Doesn't see internal storage.
I dont have an Sd card it seems it is looking for the Sd card by default and not the internal storage.
Sorry for being a noob but if i didnt have a backup i would be stuck because it seems theres no other way to put anything on the internal storage right now
Yes me too sd-card doesn't mount but still have all my
info tho... Rom works great only thing sd-card issue and try
Restore data the Rom completely stop working so had nandroid
backup to go to my old Rom... Smh need my data once dat fix will flash
Again
