Using advance restore on recovery..do you how fix sd-card issue?
So with this Rom flashing is the same as any except i just cannot restore my data which kind of sucks but oh well.
Do i need to format my internal memory and what does sneaky_1 mean by not using giantpune's gingerbread kernel. Does the Rom come with a new kernal that will just overwrite the old one. Lastly what is the Gapps suppose to do?
No my external sd-card won't read so I kould have
my pics n music?
Works wonderfully, I can do with-out the camera and nfc for a bit. The flashlight option is disabled in the power toggles but I take it that comes with the camera. Great work I would like to donate please.
No but the kernel that comes with the rom has the same features as giantpunes kernel since it's based on his kernel source with my modifications to make it compatible with ics and I also added 3 new governors to the kernel.Sorry if I missed this, but is giantpunes kernel on here, if not will it work?
Yes wen klick mount sd-card it says damage sd-card but its
not tho works fine on other roms why seems like I'm only one
this issue?
I'm not sure how credible bug reports are going to be from people that are restoring data from a stock based gingerbread rom to CM9. Same if someone is running a non stock kernel.I restored data with a couple of apps using Titanium Backup and everything works fine.
I'll see if I can get it fixed.Sandisk brand sd-card does read on other roms
Try this. Go to settings,storage then press the menu button and select storage configuration then check use internal storage.
