Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
Installed cm9 and got stuck in a bootloop on the cm9 boot animation. Here are the steps i took.
1. Wipe cache
2. Wipe dalvik cache twice
3. Backup
4. Flash cm9 zip
Did i miss a step?
Hi, Folks:
Been lurking in this thread, eagerly following along for a camera fix. Most everything else looks and works great, though. Can't wifi tether, but no matter because bluetooth tether works great and I prefer this method anyhow :-)
I've been poking around doing some research as well and I think I might have a lead.
This stuff in logcat:
07-17 12:42:46.117 E/MsmCameraDevice(137): __ioctl:: failed. cmd = 21, error = Bad address
07-17 12:42:46.117 E/MsmCameraDevice(137): Failed to get I2C sensor data.
07-17 12:42:46.117 E/MsmCameraDevice(137): Unable to communicate with the device.
When it references a "bad address", I wonder if - and this is a suggestion I am culling from another developer's post over at RootzWiki (can't post the link as am newly registered on this forum) referencing issues with ICS and camera functionality (seems to be not specific to CM9, but ICS in general) - the address in question is not occupied with other data, hence the inability of the camera to access it.
Can we have the camera use another address? Or get whatever is in the way, out?
Just thought I throw this out there. Other thoughts that came to mind for me involve recompiling the kernel, as perhaps an option that needs to be turned on there, is not. I had to do this years ago when I was trying to get wifi working on a laptop running Linux. Certain options had to be set in the kernel for things to work.
All in all, very glad to have you guys working so diligently on this, it's a great step up from the stock ROM.
Keep up the good work!
Any closer with an updated change log?
Nothing really major. Just updated the tree a little, updated adreno libs and added the stock music player. I didn't think it was worth updating the change log.
Any closer with camera?
It loads further but still crashes. I don't see any crash with mediaserver anymore but maybe I missed it.
Okay thanks I think most people are used to seeing an updated change log whenever a new build of something is released even if its nothing major.
Thanks to everyone involved and their efforts in making the Elite a better device. Looking forward to upgrading to CM as it will bring new life to this phone. Thanks Androidforums!
Currently tracking down the cause of the performance issues.
Thanks I just went back to the pervious version. By the way I am having a problem with the top bar. I will simply freeze after a while! The battery will stop changing( It will stay on 43% and just stick like that even when it is charged or goes above or below that about-phone-status shows the correct percentage ) The time will stop moving on the status bar and somtimes the drop down bar just stops showing anything other than virgin mobile at the bottom or no service.
The time does change if I go to System-Status bar- AM/PM style tap that and press any style but it then stops again:(
You might try an app called notification restart until the problem is fixed. There was a bug in on cm7 ROM I used to use where swiping away a notification would get stuck and this app helped until it was fixed.
I just wanted to thank you phenom for all your hard work on getting ics running on the Elite, I have officially retired my elite and moved onto the new F3. Keep up the good work man. Maybe I'll see ya on the F3 forums some day.
now im having the same issue as other with devhost, it gets to the end and wont actually finish, does anyone have both zips they would be willing to upload somewhere else for me? Or phenom if you can upload them to an alternate location that would be awesome thanks. I would need the sprint zip the virgin one finished
Are you still having trouble downloading?
A lot closer to camera.
Here is a logcat if anyone wants to help figure out the problem.
[HIGH]08-05 15:31:19.205: I/QualcommCameraHardware(1175): Parameter HFR is not supported for this sensor
08-05 15:31:19.286: D/CameraHAL(1175): camera_cancel_auto_focus
08-05 15:31:19.286: D/CameraHAL(1175): camera_get_parameters
08-05 15:31:19.286: D/CameraHAL(1175): camera_set_parameters
08-05 15:31:19.296: I/QualcommCameraHardware(1175): setRecordSize: preview dimensions: 640x480
08-05 15:31:19.296: I/QualcommCameraHardware(1175): setRecordSize: video dimensions: 640x480
08-05 15:31:19.296: I/QualcommCameraHardware(1175): Parameter Rolloff is not supported for this sensor
08-05 15:31:19.296: I/QualcommCameraHardware(1175): setMCEValue: setting MCE value of enable
08-05 15:31:19.296: E/QualcommCameraHardware(1175): ### setTouchAfAec: TOUCHED AF AEC SET
08-05 15:31:19.296: I/QualcommCameraHardware(1175): setRedeyeReduction: setting Redeye Reduction value of disable
08-05 15:31:19.296: E/CAM_FD(1175): config_proc_CAMERA_SET_REDEYE_REDUCTION: mode =0
08-05 15:31:19.296: I/QualcommCameraHardware(1175): updateFocusDistances: setting KEY_FOCUS_DISTANCES as 3.408478,3.408614,3.408750
08-05 15:31:19.296: E/QualcommCameraHardware(1175): ### setFocusMode: Focus Type : auto
08-05 15:31:19.296: E/CAM_FD(1175): [KSS_CAF]#####config_proc_CAMERA_SET_LG_CAF: ctrl->isp3aCtrl.isp3a_input.af_input.isLGCAF = 0x1
08-05 15:31:19.296: I/QualcommCameraHardware(1175): Parameter HFR is not supported for this sensor
08-05 15:31:19.406: D/CameraHAL(1175): camera_get_parameters
08-05 15:31:19.416: D/CameraHAL(1175): camera_set_parameters
08-05 15:31:19.416: I/QualcommCameraHardware(1175): setRecordSize: preview dimensions: 640x480
08-05 15:31:19.416: I/QualcommCameraHardware(1175): setRecordSize: video dimensions: 640x480
08-05 15:31:19.416: I/QualcommCameraHardware(1175): Parameter Rolloff is not supported for this sensor
08-05 15:31:19.416: I/QualcommCameraHardware(1175): setMCEValue: setting MCE value of enable
08-05 15:31:19.416: E/QualcommCameraHardware(1175): ### setTouchAfAec: TOUCHED AF AEC SET
08-05 15:31:19.416: I/QualcommCameraHardware(1175): setRedeyeReduction: setting Redeye Reduction value of disable
08-05 15:31:19.416: E/CAM_FD(1175): config_proc_CAMERA_SET_REDEYE_REDUCTION: mode =0
08-05 15:31:19.416: I/QualcommCameraHardware(1175): updateFocusDistances: setting KEY_FOCUS_DISTANCES as 3.408478,3.408614,3.408750
08-05 15:31:19.416: E/QualcommCameraHardware(1175): ### setFocusMode: Focus Type : auto
08-05 15:31:19.416: E/CAM_FD(1175): [KSS_CAF]#####config_proc_CAMERA_SET_LG_CAF: ctrl->isp3aCtrl.isp3a_input.af_input.isLGCAF = 0x1
08-05 15:31:19.416: I/QualcommCameraHardware(1175): Parameter HFR is not supported for this sensor
08-05 15:31:19.416: D/CameraHAL(1175): camera_auto_focus
08-05 15:31:19.426: E/QualcommCameraHardware(1175): ##### runAutoFocus: af start and AEC(mode 2)
08-05 15:31:19.426: I/QualcommCameraHardware(1175): updateFocusDistances: setting KEY_FOCUS_DISTANCES as 3.408478,3.408614,3.408750
08-05 15:31:19.426: D/CameraHAL(1175): wrap_notify_callback: type 4
08-05 15:31:19.426: D/CameraHAL(1175): wrap_notify_callback: CAMERA_MSG_FOCUS
08-05 15:31:19.426: D/CameraHAL(1175): camera_auto_focus
08-05 15:31:19.436: D/CameraHAL(1175): wrap_notify_callback: type 4
08-05 15:31:19.436: D/CameraHAL(1175): wrap_notify_callback: CAMERA_MSG_FOCUS
08-05 15:31:19.436: D/CameraHAL(1175): camera_auto_focus
08-05 15:31:19.436: E/QualcommCameraHardware(1175): ##### runAutoFocus: af start and AEC(mode 2)
08-05 15:31:19.436: I/QualcommCameraHardware(1175): updateFocusDistances: setting KEY_FOCUS_DISTANCES as 3.408478,3.408614,3.408750
08-05 15:31:19.436: D/CameraHAL(1175): camera_cancel_auto_focus
08-05 15:31:19.436: D/CameraHAL(1175): camera_get_parameters
08-05 15:31:19.446: D/CameraHAL(1175): camera_set_parameters
08-05 15:31:19.446: I/QualcommCameraHardware(1175): setRecordSize: preview dimensions: 640x480
08-05 15:31:19.446: I/QualcommCameraHardware(1175): setRecordSize: video dimensions: 640x480
08-05 15:31:19.446: I/QualcommCameraHardware(1175): Parameter Rolloff is not supported for this sensor
08-05 15:31:19.446: I/QualcommCameraHardware(1175): setMCEValue: setting MCE value of enable
08-05 15:31:19.446: E/QualcommCameraHardware(1175): ### setTouchAfAec: TOUCHED AF AEC SET
08-05 15:31:19.446: I/QualcommCameraHardware(1175): setRedeyeReduction: setting Redeye Reduction value of disable
08-05 15:31:19.446: E/CAM_FD(1175): config_proc_CAMERA_SET_REDEYE_REDUCTION: mode =0
08-05 15:31:19.446: I/QualcommCameraHardware(1175): updateFocusDistances: setting KEY_FOCUS_DISTANCES as 3.408478,3.408614,3.408750
08-05 15:31:19.446: E/QualcommCameraHardware(1175): ### setFocusMode: Focus Type : auto
08-05 15:31:19.446: E/CAM_FD(1175): [KSS_CAF]#####config_proc_CAMERA_SET_LG_CAF: ctrl->isp3aCtrl.isp3a_input.af_input.isLGCAF = 0x1
08-05 15:31:19.446: I/QualcommCameraHardware(1175): Parameter HFR is not supported for this sensor
08-05 15:31:19.526: D/CameraHAL(1175): camera_cancel_auto_focus
08-05 15:31:19.526: D/CameraHAL(1175): camera_get_parameters
08-05 15:31:19.546: D/CameraHAL(1175): camera_set_parameters
08-05 15:31:19.546: I/QualcommCameraHardware(1175): setRecordSize: preview dimensions: 640x480
08-05 15:31:19.546: I/QualcommCameraHardware(1175): setRecordSize: video dimensions: 640x480
08-05 15:31:19.556: I/QualcommCameraHardware(1175): Parameter Rolloff is not supported for this sensor
08-05 15:31:19.556: I/QualcommCameraHardware(1175): setMCEValue: setting MCE value of enable
08-05 15:31:19.556: E/QualcommCameraHardware(1175): ### setTouchAfAec: TOUCHED AF AEC SET
08-05 15:31:19.556: I/QualcommCameraHardware(1175): setRedeyeReduction: setting Redeye Reduction value of disable
08-05 15:31:19.556: E/CAM_FD(1175): config_proc_CAMERA_SET_REDEYE_REDUCTION: mode =0
08-05 15:31:19.556: I/QualcommCameraHardware(1175): updateFocusDistances: setting KEY_FOCUS_DISTANCES as 3.408478,3.408614,3.408750
08-05 15:31:19.556: E/QualcommCameraHardware(1175): ### setFocusMode: Focus Type : auto
08-05 15:31:19.556: E/CAM_FD(1175): [KSS_CAF]#####config_proc_CAMERA_SET_LG_CAF: ctrl->isp3aCtrl.isp3a_input.af_input.isLGCAF = 0x1
08-05 15:31:19.566: I/QualcommCameraHardware(1175): Parameter HFR is not supported for this sensor
08-05 15:31:19.626: D/CameraHAL(1175): camera_get_parameters
08-05 15:31:19.636: D/CameraHAL(1175): camera_set_parameters
08-05 15:31:19.636: I/QualcommCameraHardware(1175): setRecordSize: preview dimensions: 640x480
08-05 15:31:19.636: I/QualcommCameraHardware(1175): setRecordSize: video dimensions: 640x480
08-05 15:31:19.636: I/QualcommCameraHardware(1175): Parameter Rolloff is not supported for this sensor
08-05 15:31:19.636: I/QualcommCameraHardware(1175): setMCEValue: setting MCE value of enable
08-05 15:31:19.636: E/QualcommCameraHardware(1175): ### setTouchAfAec: TOUCHED AF AEC SET
08-05 15:31:19.646: I/QualcommCameraHardware(1175): setRedeyeReduction: setting Redeye Reduction value of disable
08-05 15:31:19.646: E/CAM_FD(1175): config_proc_CAMERA_SET_REDEYE_REDUCTION: mode =0
08-05 15:31:19.646: I/QualcommCameraHardware(1175): updateFocusDistances: setting KEY_FOCUS_DISTANCES as 3.408478,3.408614,3.408750
08-05 15:31:19.646: E/QualcommCameraHardware(1175): ### setFocusMode: Focus Type : auto
08-05 15:31:19.646: E/CAM_FD(1175): [KSS_CAF]#####config_proc_CAMERA_SET_LG_CAF: ctrl->isp3aCtrl.isp3a_input.af_input.isLGCAF = 0x1
08-05 15:32:19.795: E/CAM_FD(1175): ...config thread select timeout...
08-05 15:38:08.024: E/CAM_FD(1175): ...config thread select timeout...
08-05 15:38:08.925: D/CameraHAL(1175): camera_disable_msg_type: type 1024
08-05 15:38:08.925: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_PREVIEW_METADATA
08-05 15:38:08.925: D/CameraHAL(1175): camera_disable_msg_type: type 16
08-05 15:38:08.925: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_PREVIEW_FRAME
08-05 15:38:08.925: D/CameraHAL(1175): camera_stop_preview
08-05 15:38:08.925: I/QualcommCameraHardware(1175): stopPreviewInternal E: 0
08-05 15:38:08.925: I/QualcommCameraHardware(1175): stopPreviewInternal X: 0
08-05 15:38:08.925: E/Camera-JNI(1186): Null byte array!
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: type 16
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_PREVIEW_FRAME
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: type 65535
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_ERROR
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_SHUTTER
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_FOCUS
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_ZOOM
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_VIDEO_FRAME
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_POSTVIEW_FRAME
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_RAW_IMAGE
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_COMPRESSED_IMAGE
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_RAW_IMAGE_NOTIFY
08-05 15:38:08.935: D/CameraHAL(1175): camera_disable_msg_type: CAMERA_MSG_PREVIEW_METADATA
08-05 15:38:08.935: D/CameraHAL(1175): camera_stop_preview
08-05 15:38:08.935: I/QualcommCameraHardware(1175): stopPreviewInternal E: 0
08-05 15:38:08.935: I/QualcommCameraHardware(1175): stopPreviewInternal X: 0
08-05 15:38:08.935: D/CameraHAL(1175): camera_cancel_picture
08-05 15:38:08.935: I/QualcommCameraHardware(1175): cancelPicture: E
08-05 15:38:08.935: I/QualcommCameraHardware(1175): cancelPicture: setting mSnapshotCancel to true
08-05 15:38:08.935: I/QualcommCameraHardware(1175): cancelPicture: X: 0
08-05 15:38:08.935: D/CameraHAL(1175): camera_release
08-05 15:38:08.935: I/CameraService(1175): Destroying camera 0
08-05 15:38:08.935: D/CameraHAL(1175): camera_device_close
08-05 15:38:08.935: I/QualcommCameraHardware(1175): ~QualcommCameraHardware E
08-05 15:38:08.935: E/mm-camera stacktrace(1175): +++ DELETING LEAKED MEMORY AT 0x239a0 (8 REMAINING)
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 15 0xa77307b6
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 14 0xa770b69c
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 13 0xa770dbfa
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 12 0xa7913eda
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 11 0xa7918ee6
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 10 0xa7919066
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 9 0x40f5cb34
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 8 0x405b3ba6
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 7 0x405544b8
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 6 0x405b1d64
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 5 0x40137f46
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 4 0x4013b2a8
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 3 0x4013b486
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 2 0x40140780
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 1 0x400f6a20
08-05 15:38:08.935: E/mm-camera stacktrace(1175): +++ DELETING LEAKED MEMORY AT 0x21b70 (7 REMAINING)
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 7 0xa77307b6
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 6 0xa770b69c
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 5 0xa7715174
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 4 0xa77105b2
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 3 0xa7710930
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 2 0x40055dd8
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 1 0x40055908
08-05 15:38:08.935: E/mm-camera stacktrace(1175): +++ DELETING LEAKED MEMORY AT 0x20f18 (6 REMAINING)
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 8 0xa77307b6
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 7 0xa770b69c
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 6 0xa7720fd4
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 5 0xa7715166
08-05 15:38:08.935: E/mm-camera stacktrace(1175): +++ DELETING LEAKED MEMORY AT 0x202c0 (5 REMAINING)
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 6 0xa7717e96
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 5 0xa7715160
08-05 15:38:08.935: E/mm-camera stacktrace(1175): +++ DELETING LEAKED MEMORY AT 0x1c100 (4 REMAINING)
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 6 0xa7717e86
08-05 15:38:08.935: E/mm-camera stacktrace(1175): +++ DELETING LEAKED MEMORY AT 0x186a0 (3 REMAINING)
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 6 0xa7717e6c
08-05 15:38:08.935: E/mm-camera stacktrace(1175): +++ DELETING LEAKED MEMORY AT 0x1baf8 (2 REMAINING)
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 6 0xa771ff9c
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 5 0xa771515a
08-05 15:38:08.935: E/mm-camera stacktrace(1175): +++ DELETING LEAKED MEMORY AT 0x18c18 (1 REMAINING)
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 6 0xa7726c32
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 5 0xa77242b2
08-05 15:38:08.935: E/mm-camera stacktrace(1175): 4 0xa7710574
08-05 15:38:08.935: I/QualcommCameraHardware(1175): ~QualcommCameraHardware X
08-05 15:38:08.965: W/AudioFlinger(1175): session id 3 not found for pid 1175
08-05 15:38:08.965: W/AudioFlinger(1175): session id 4 not found for pid 1175
08-05 15:38:09.486: W/AudioService(262): stream was not muted by this client
08-05 15:38:09.486: E/AudioService(262): Could not get client death handler for stream: 1
08-05 15:38:09.486: E/AudioService(262): Could not get client death handler for stream: 2
08-05 15:38:09.486: E/AudioService(262): Could not get client death handler for stream: 3
08-05 15:38:09.486: E/AudioService(262): Could not get client death handler for stream: 5
08-05 15:38:09.536: I/VolumePanel(262): changeOverlayStyle : 2
08-05 15:38:12.879: A/libc(1175): Fatal signal 11 (SIGSEGV) at 0xa77246f8 (code=1)
08-05 15:38:13.279: I/DEBUG(1220): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
08-05 15:38:13.279: I/DEBUG(1220): Build fingerprint: 'lge/m3s/m3s:4.0.4/IMM76L/eng.phenomx4.20130805.093403:userdebug/test-keys'
08-05 15:38:13.279: I/DEBUG(1220): pid: 1175, tid: 1207 >>> /system/bin/mediaserver <<<
08-05 15:38:13.279: I/DEBUG(1220): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr a77246f8
08-05 15:38:13.279: I/DEBUG(1220): r0 00000000 r1 4171fe34 r2 00000000 r3 00000000
08-05 15:38:13.279: I/DEBUG(1220): r4 a7792c88 r5 a7792c88 r6 00000006 r7 00000000
08-05 15:38:13.279: I/DEBUG(1220): r8 00000001 r9 a7792c94 10 4171fe34 fp a7792ca8
08-05 15:38:13.279: I/DEBUG(1220): ip 4171fe20 sp 4171fe20 lr a77246f9 pc a77246f8 cpsr 600e0030
08-05 15:38:13.279: I/DEBUG(1220): d0 6d736d2f76656463 d1 2f6172656d61636f
08-05 15:38:13.279: I/DEBUG(1220): d2 74736e6f6320656e d3 4520726f74637566
08-05 15:38:13.279: I/DEBUG(1220): d4 0069007300730069 d5 006f0043006e006f
08-05 15:38:13.279: I/DEBUG(1220): d6 006f00720074006e d7 00720065006c006c
08-05 15:38:13.279: I/DEBUG(1220): d8 0000000000000000 d9 0000000000000000
08-05 15:38:13.279: I/DEBUG(1220): d10 0000000000000000 d11 0000000000000000
08-05 15:38:13.279: I/DEBUG(1220): d12 0000000000000000 d13 0000000000000000
08-05 15:38:13.279: I/DEBUG(1220): d14 0000000000000000 d15 0000000000000000
08-05 15:38:13.279: I/DEBUG(1220): d16 3fbbe774dc28f5c2 d17 3fefae147ae147ae
08-05 15:38:13.279: I/DEBUG(1220): d18 4000000000000000 d19 bfcd9f80f7646cc2
08-05 15:38:13.279: I/DEBUG(1220): d20 3f1150e6230c241f d21 bebbb46853488199
08-05 15:38:13.279: I/DEBUG(1220): d22 3ff0000000000000 d23 3fe999a1f2459fc7
08-05 15:38:13.279: I/DEBUG(1220): d24 3e66376972bea4d0 d25 0000000000000000
08-05 15:38:13.279: I/DEBUG(1220): d26 0000000000000000 d27 0000000000000000
08-05 15:38:13.279: I/DEBUG(1220): d28 0000000000000000 d29 0000000000000000
08-05 15:38:13.279: I/DEBUG(1220): d30 0000000000000000 d31 0000000000000000
08-05 15:38:13.279: I/DEBUG(1220): scr 80000010
08-05 15:38:13.339: I/DEBUG(1220): #00 pc a77246f8
08-05 15:38:13.339: I/DEBUG(1220): #01 lr a77246f9 <unknown>
08-05 15:38:13.349: I/DEBUG(1220): code around pc:
08-05 15:38:13.349: I/DEBUG(1220): a77246d8 ffffffff ffffffff ffffffff ffffffff ................
08-05 15:38:13.349: I/DEBUG(1220): a77246e8 ffffffff ffffffff ffffffff ffffffff ................
08-05 15:38:13.349: I/DEBUG(1220): a77246f8 ffffffff ffffffff ffffffff ffffffff ................
08-05 15:38:13.349: I/DEBUG(1220): a7724708 ffffffff ffffffff ffffffff ffffffff ................
08-05 15:38:13.349: I/DEBUG(1220): a7724718 ffffffff ffffffff ffffffff ffffffff ................
08-05 15:38:13.349: I/DEBUG(1220): code around lr:
08-05 15:38:13.349: I/DEBUG(1220): memory map around addr a77246f8:
08-05 15:38:13.349: I/DEBUG(1220): 42060000-42061000 /system/lib/libgenlock.so
08-05 15:38:13.349: I/DEBUG(1220): (no map for address)
08-05 15:38:13.349: I/DEBUG(1220): a7900000-a791e000 /system/lib/libcamera.so
08-05 15:38:13.349: I/DEBUG(1220): stack:
08-05 15:38:13.349: I/DEBUG(1220): 4171fde0 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fde4 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fde8 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fdec 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fdf0 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fdf4 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fdf8 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fdfc 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe00 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe04 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe08 4171fe34
08-05 15:38:13.349: I/DEBUG(1220): 4171fe0c a7792c88
08-05 15:38:13.349: I/DEBUG(1220): 4171fe10 a7792c88
08-05 15:38:13.349: I/DEBUG(1220): 4171fe14 a7792c88
08-05 15:38:13.349: I/DEBUG(1220): 4171fe18 df0027ad
08-05 15:38:13.349: I/DEBUG(1220): 4171fe1c 00000000
08-05 15:38:13.349: I/DEBUG(1220): #00 4171fe20 4171feb4
08-05 15:38:13.349: I/DEBUG(1220): 4171fe24 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe28 00040b43
08-05 15:38:13.349: I/DEBUG(1220): 4171fe2c a7759ae0
08-05 15:38:13.349: I/DEBUG(1220): 4171fe30 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe34 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe38 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe3c 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe40 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe44 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe48 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe4c 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe50 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe54 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe58 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe5c 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe60 00000000
08-05 15:38:13.349: I/DEBUG(1220): 4171fe64 00000000
08-05 15:38:14.160: I/BootReceiver(262): Copying /data/tombstones/tombstone_06 to DropBox (SYSTEM_TOMBSTONE)
08-05 15:38:14.170: I/DEBUG(1220): debuggerd committing suicide to free the zombie!
08-05 15:38:14.180: W/Camera(1186): Camera server died!
08-05 15:38:14.180: W/AudioSystem(262): AudioFlinger server died!
08-05 15:38:14.180: W/AudioSystem(262): AudioPolicyService server died!
08-05 15:38:14.180: I/ServiceManager(143): service 'media.audio_flinger' died
08-05 15:38:14.180: I/ServiceManager(143): service 'media.player' died
08-05 15:38:14.180: I/ServiceManager(143): service 'media.camera' died
08-05 15:38:14.180: I/ServiceManager(143): service 'media.audio_policy' died
08-05 15:38:14.190: I/DEBUG(1254): debuggerd: Aug 5 2013 09:49:18
08-05 15:38:14.551: I/CameraService(1253): CameraService started (pid=1253)
08-05 15:38:14.561: I/QualcommCameraHardware(1253): getCameraInfo: IN
08-05 15:38:14.561: I/QualcommCameraHardware(1253): getCameraInfo: loading libqcamera at 0xb000ead8
08-05 15:38:14.561: I/QualcommCameraHardware(1253): getCameraInfo: numOfCameras = 1
08-05 15:38:14.561: I/QualcommCameraHardware(1253): Camera sensor 0 info:
08-05 15:38:14.561: I/QualcommCameraHardware(1253): camera_id: 0
08-05 15:38:14.561: I/QualcommCameraHardware(1253): modes_supported: 5
08-05 15:38:14.561: I/QualcommCameraHardware(1253): position: 0
08-05 15:38:14.561: I/QualcommCameraHardware(1253): sensor_mount_angle: 0
08-05 15:38:14.561: I/QualcommCameraHardware(1253): getCameraInfo: OUT
08-05 15:38:14.561: D/CameraHAL(1253): camera_get_number_of_cameras: number:1
08-05 15:38:15.682: E/AudioService(262): Media server died.
08-05 15:38:15.682: E/AudioService(262): Media server started.[/HIGH]Or pastebin
08-05 15:31:19.205: I/QualcommCameraHardware(1175): Parameter HFR is not support - Pastebin.com
Stock camera app force closes immediately because it can't set the orientation. 3rd party camera app (I'm using CameraMX) does not force close but has a black preview screen. trying to take a picture either force closes or makes the app stop responding but I can however turn on the flash with CameraMX so that means I'm close to getting the camera working.
I get no more crashes from mediaserver when opening CameraMX but there is still one error I still get repeatedly which is "CAM_FD: ...config thread select timeout...". Taking pictures and video still doesn't work.
