Wireless (2.4 GHz / eth1)
Enable Wireless: YES
MAC Address: **:**:**:**:**:**
Wireless Mode: Access Point
Wireless Network Mode: B/G Mix (Tried both separately also)
SSID: Netgear
Broadcast: YES
Channel: 6 (Tried 8 also)
Channel Width: 20MHZ
Security: None
I also noticed the rom changed my elites mac address
Yes I'm running the same rom I uploaded. I haven't touched the wifi since maybe the first month I release the alpha.Phenomx4
You sure you're running the same rom? Maybe install the rom you uploaded clean and see if you can connect to wifi.
I tried a couple of different routers that allows bgn with wpapsk. Everything else including the phone with your last version rom connects.
Alright. I'll do a clean install and see if I get the problem.Phenomx4: I know you think you're running the same rom you uploaded but I suspect something is different. That's why I suggest you do a clean install with the file and see if wifi works. You can restore a nandroid if it works. It will be much easier to diagnose if you have the same problem. I guess it's possible that it's some weird hardware difference but that seems unlikely. Something happened since the last release. I did a clean install with gapps and had the same problem with no other files installed.
Has anyone done a clean install of the new version with wifi working?
Looks like it fails to get an IP address 10 times before it gives up. Is anyone else having trouble connecting to a wifi ap on the latest build.
Confirmed. Clean install including gapps. Doesn't connect to WiFi. Cycles through a half dozen times and then finally says, 'Avoided, poor Internet Connection'. I'm 10 foot from my router - doubt if I'm getting poor internet connection as I get perfect connection under Sleipner.
FYI, I set IP (under Wifi --> Advanced) to static and everything works good.
Also, confirmed bar code scanner works (which was a big deal for me)
I don't believe the barcode scanner uses any type of autofocus - at least the one I use doesn't seem to. Looks like the camera issue is related to autofocus.
