Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
8-19-13 Update still has problems.
WiFi HotSpot/AP does not work. Accessing the Settings --> Profile per the FAQ in the OP renders an error message stating 'Unfortunately, Settings has stopped.' I'd really like to see this working as I use WiFi Hotspot for my profession as a Network Engineer when I'm on a job site. Great when there is no local WiFi.
LED Torch Application does not work (third party app does).
Had to install ROM update three times before it would allow and type of syncing. Kept getting errors from GMail sync stating it was unavailable, however, when I would restore to previous version, everything was fine.
I see some people say it seems faster. I don't see any speed increase. Still a little laggy in some applications - especially in Link2SD.
One good thing, I've never experienced any random reboots - which is what I periodically get using Sleipner.
Overall, pretty good and with some ICS Inverted Apps, pretty cool.
Keep at it :D
Keep at it :D
Native tethering doesn't work. Use a 3rd party app.
I don't see that in the OP . . .
I do see, however, a short checklist of what do do to get WiFi Hotspot working.
Would be good to get this working natively - one less app to install and maintain.
Anyway, works on Barnacle.
I'm going to need a tester who are having this problem to try out a couple of builds. Who's interested?
do i need to have any logcat knowledge cause i have none:( but ill still try it and say any basic things that is messed up such as blue tooth wifi performance etc.. and im virgin mobile btw.
I don't need anymore test at the moment because I've already fixed the wifi issue.
Sorry for the double post but are the download links working? I can get the gapps but I cant download the update on my comp or my phone. :(
- works now :)
Wow, I have never once had Firefox run well on this phone so I've been using Dolphin, but either phenom did something to the performance or Mozilla fixed a lot because Fitefox is pretty fast (launches and runs faster than Dolphin).
Sent from my LG-VM696 using Tapatalk 4
My sincere thanks to all who worked tirelessly on this Rom,....Soon as I'm working again I'll be making donations all around!!!
#YouGuysAreTheBest
Hmm, when I try to flash the camera fix through recovery it just says; "Can't open /sdcard/camerafixoecm9.zip (bad) Installation aborted."
Edit 2: Ok that was weird, I downloaded it again and the md5's match now lol :P
