Bluntmagic95
Ive had problems like that with CWM i would try and restore from an older backup and it would say b
MD5 Mis match
MD5 Mis match
Any problems with the camera?
Not working for me. I flashed it then rebooted and opened camera and it says can not connect to camera
Did you flash the camera fix a few posts back?
Yes i did flash the camera fix. I went back and flashed it again. Could it be cause im using the first buill from the beginning of this thread
Its aliiivee!!!!!
But flash dousnt seem to work except for flashlight apps and yea the exposure seems a bit low other than that its AMAZING!!!!
Yea that was my question. Does flash work?
Video recording now works!
In a minute.Is there a patch available?
In a minute.
Did stock rom have auto focus while recording video?
It seems to work now. Also looking into increasing video quality by increasing the bit-rate. I think I'm going to release a full rom instead of a patch since there were other changes other than just the camera wrapper.Doesn't appear to.
Updated. Panorama still doesn't work but it's not a camera issue, it's a graphic issue.
Feels good putting camera in the working section.
