Quick question on the rom info it says its from the 19 do i download that one?
so one thing i've noticed is that when i get a notification my soft keys don't light up anymore... it used to be when i got a sms or mms or someone left a voicemail the soft keys would flash... no go since installing cm9...
any clues? fixes?
thanks.
Where do i download the latest build?
Well done Phenom, its running well and seems very stable so far. There is one thing I've noticed and that's the email bug (no visible text in the body of the email) in both the native app and Gmail. I have found K9 mail or Maildroid are good alternatives for the moment. Looking forward to a "Stable" label soon. Again, well done man.
Great to have the camera working! I know I mentioned this before, but WiFi shuts down when BlueTooth is started. Still can get the 3g, but streaming is someone limited. I'll see if I can get a logcat, but not sure what will be needed to debug this.
That's a cm9 thing. Hope that's fixed in cm10.
Just tried this right now and wifi is working fine. It could be a hardware issue you are having. Is anyone else having this problem?
Looks like the battery drain is still high. I've been running 1 hour 10 minutes now and lost 7%. Is anyone else seeing similar drain or should I try a new clean install?
Anyone having issues making a video??
this might have been covered elsewhere in the thread but is there a way to uninstall stock apps? like i want to get rid of superuser because i prefer supersu but the only option is disable and that conflicts when trying to install super su...
What's the issue you're having with video recording?
Yeah I read that. There's a fix(stock mail app) by going into manage apps, clearing data then signing in again.
