Anyone else having trouble downloading mms sometimes ?
I'm having the same problem. I'll delete a photo received via messaging and several hours, the image will suddenly be downloaded. Very strange.
Upvote
0
This is already known. Some sort of conflict between lib camera and genlock crashes the mediaserver after leaving preview or exiting the camera.
Confirming what was happening on my phone.
Is this something that has a low priority due to it working - just a few more steps?
I'm having the Google sync error..I lose data the play store and not able to go online I had to reset the phone plz fix
Google search closes with no error and nothing of note in the logcat. Tried wiping cache and fixing permissions no joy. (8/30 build)
Also the voice search is weird as though it were hdpi or something?
CWM6
Reflashing GApps and fixing permissions sorted it.
I'm currently using CWM based Recovery v5.0.2.8. Wouldn't mind updating that to CWM 6 if you have a link for that recovery.
Hey guys, I'm new here, and I'm new to rooting and the likes like that, I downloaded CM9, wiped everything and flashed the rom, but google play doesn't show up. I would really like to use it, but im a newb when it comes to this kind of stuff and have no idea of what to do to fix it, any help would be appreciated, thanks!
Originally posted by Phenom...
https://www.dropbox.com/s/d2wwq659lgztou0/CWM_recovery_OE .zip
Reboot into recovery and flash then advanced option reboot recovery.
I was using the 'timefix' text file with previous version of CWM so that backups were correctly time stamped, however, I noticed this has no effect with the newer CWM V6. Is there another fix for ensuring time stamps are correct under the CWM V6?
You could use TWRP recovery. Still wrong time and date, but you could just name the backups what you want.
Its also not compatible with CWM backups. So you could just flash between CWM and TWRP backing up and restoring.
