Anyone figured out why mms is only working sometimes? Only 25% of my incoming pic texts can ever be downloaded
Do you have the 8/21 build? If so can you pull the Mms.apk from system/app and I think I can fix the mms issue.
I'm on the newest build
Clocked at 1024 MHz I/O sio governor on demand
Only background data is enabled
I have it fixed temporarily till phenom gets to it standby...
Temp fix, its my themed version I'm using and also includes full screen caller id for the phone.
Wipe cache and dalvik then mount system, flash zip and profit. Report any issues on my CM9 theme thread. If you don't follow the instructions don't post issues. Thanks in advance.
http://db.tt/0D7hrJDn
That worked . Thanks. Now if only a fix for the 3g that won't stay locked on a signal
I honestly think for this device the radio needs updated and this will have to come from Sprint, Virgin or LG...
That sucks.... because you know they'll never do it lol
I'm still on the ZV4 baseband and it seemed the same as the ZV5Does anyone know if the ZV4 baseband (if there was a different one) was better?
Seems the battery percent reported is not accurate. My phone showed like 7% when I turned it off and 20% when I turned it back on. Maybe wiping the battery status will fix these issues?
Anyone else having problems connecting to hidden ssid's over wifi.
