adrenaline163
When I try to download the zip from sdcard I get an error in Emmc/ the zip file (status 7). Is there anyway to fix this?
Everything I've read said wiping battery stats is a "old wives tale"...
I think that is usually true but my phone was reporting completely incorrect %. It dropped like 10% in just a few minutes. Other times it stayed on the same % for an hour. It was dying after just a few hours with little or no use.
I wiped the battery stats and it seems to be better for now.
Which recovery are you using? Status 7 is usually a recovery error, updater script error or a build.prop error.
Yes you need to update to twrp or CM6 both of which work well.I'm using cwm v5. I used it to install sleipner. Do I need twrp? I've heard bad things about it. It is a build prop error. But I'm not sure what that means
Links and info here...
[Recovery][Beta] TWRP 2.5 - Android Forums
So basically I will eventually have to switch from cwm 5 to cwn6 or twrp?
Why is every thing lagging... I keep getting random freezes when playing our searching the web. I even get a keyboard delay someone plz help this is really bothering me.. it takes me 10 to send a text or go on youtube
Is WiFi Hotspot/Tethering on the 'fix list'?
Never really got third party WiFi Tethering apps to work at all except for Barnacle - and that was very inconsistent.
Atraum try flashing the file starkraving posted. Worked a champ. Its post #1855
http://androidforums.com/showthread.php?t=722536
I only see a link for twrp here, not cwm6 zip?
Hey, has anyone experienced a problem connecting two phones running this ROM to the same router? I have one for everything, wife has one for internet, Facebook, games, etc... but we both can't be on the wifi at once it doesn't totally disconnect just allows no traffic to the first phone after the second is connected
Check the Bluetooth addresses for both phones under about phone. Back when I had the Optimus V there was an issue with this on CM roms.
It was because the Bluetooth address was just coded into the rom unlike wifi mac address is hardcoded. Since it was softcoded it was the same for all phones running the rom.
It took a dev to create a zip that assigned a random address based on phone serial.
If both your Bluetooth addresses are the same it's the same issue and the address of one of the phones needs to be changed
