I notice that if you load the camera up then exit and renter it gives an "Can't connect to the camera" error. If you wait a moment then reenter it works again. Its a little annoying but not a huge deal.
FYI - Signal bars is lower than before. My wife has the same phone and it shows more signal than mine.
Updated. You no longer need to reflash gapps every update because of the updated scripts.
Exactly what does this kernel do for everyone on the current CM build (8-23-13)?
Do we still need to copy the .xml files?
Is anyone having problems with the video recording?
I know what's going with the signal issue and it will be fixed and am looking at the wifi issue now.i've noticed with both the 8/23 and 8/30 builds the radio seems to be a bit wonky.
it switches from blue to grey as some people have noted. when the wi-fi and radio/antenna are grey i can't use wi-fi or data. i have to restart wifi and then the wi-fi and radio turn blue and are functional again.
also still showing my signal strength less than what it usually is. it's typically one bar lower than what i'm used to seeing wherever i go.
is this related to the known data issues with OE? or is it something new?
thx.
When you say signal issue does that mean evdo will be fixed?
Thanks for the update.
The gamil issue with the blank page can be annoying. I notice if you kill the app then load it up again it typically works. I enabled killing apps on long press from the dev options.
I'm confused about this bug. How is it stuck on 1x but give 3G speeds?
No not that but I've been looking at the issue.
