Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
10 hours on a single charge with normal usage and a ton of widgets running. :)
Hmm. I'm told this is cm9, but I think its using Trebuchet. I did find a setting to allow resizing of widgets, so I'm trying that. Also, please excuse my noob, but where is this root helper of which you speak?
In trebuchet just adjust your grid layout in settings/launcher 5x5 or whatever I think trebuchet goes to 7x7 and apex and nova go 10x10 plus ...
Unable to apply any CM9 themes. Get an error that the theme was not properly compiled. Set theme back to stock and rebooted. Reapplied the new theme, still same error that the theme was not properly compiled.
I could see if this was one theme having a problem, it would be a theme designer issue, however, I can't get any themes to apply without getting this error.
I could see if this was one theme having a problem, it would be a developer issue, however, I can't get any themes to apply without getting this error.
You need to make sure the themes are compiled for our mdpi screens. Just add mdpi to your search results.
Flash this...
http://db.tt/os8d8PWb
Excellent ROM. Thanks so much for all of your work. The reboot and startup times are just insanely fast. Regarding battery, I just lost 4% over 1 hour and 22 minutes with NO use and everything turned off (GPS, Wi-Fi, data, etc.). Does this seem acceptable? Or should I be looking for things to tweak? Thanks!
i notice is HUGE perfomance boost when after a new fresh install. i uninstall all the animation backgrounds, i delte good voice/ talk and everyhting i dont use VIA titianum backup, and then after im done installing all my apps. i boot into recovery and wipe dalvik and cache.. reboot and its really fast...
i notice is HUGE perfomance boost when after a new fresh install. i uninstall all the animation backgrounds...
I can't seem to find the animations, would like to get rid of them, could you let me know where they are located?
Also, thank you very much for all of your hard work bringing this rom to the elite, Phenom, you are one awesome dude! May just keep this phone a little while longer now.
The little OV was / is a great phone. My wife still uses hers. Going to get her the F3 very soon.
The LG Optimus V is a great phone - especially with CyanMobile ROM installed on it. Battery charge is incredible. Can leave it off charger over night and it might go down 5 percent. ROM is very fast. I have an OE in my desk drawer loaded up with CyanMobile as my backup phone - just in case :rolleyes:
Tried to talk the developer into porting the LG Optimus V CyanMobile ROM over to the Optimus Elite. Although he admitted to having an Elite, he stated 'no time, man' :smokingsomb:. I may keep trying . . . .
Edit: Wanted to add that the camcorder actually works very well on the CyanMobile ROM. Had to replace the ported version with the Camera.apk from GingerSnap. After that, Camcorder works nicely on the Optimus V.
anyone else having problems with profiles? my settings force closes when I attempt to change settings for default profile. Thanks in advance
I never looked at the OV ROM development after I got rid of mine.
My wife's has been on BACKside forever.
She will get an upgrade this weekend. Loving my F3 and going to upgrade her phone to one.
Having trouble downloading images that are attached to text messages. Don't really get any error messages, however, nothing is ever downloaded. :confused:
Can you list current problems you are having? I'd like to take care of these before I continue to work on cm10. Logcats will be nice.
I've attached a logcat for the camcorder not working. No errors on the camcorder. Pressing the record button just flashes the button and that's it.
VirginMobile network for delivering MMS messages has been painfully slow today. As soon as I receive a photo from a test, I'll supply a logcat for the images in text messages as well.
Edit: Logcat did not attach. Will have to send via PM.
